Veritas - Innovation in Tools
OT: Story of my life!
Carole in VA
>On 12/01/05 my 60 gig hard drive crashed. The one with all my data on it. For the past 7 days I have been trying to recover what data I could before I zeroed it out. Tonight it started making a horrendous noise like it was coming apart. I figured that was the end of the line. Fairly new drive so I checked out the warranty on line. The warranty expired on 12/05/05. Arrrrgh!
Re: OT: Story of my life!
Raymond Overman in SC
>From experience, call the manufacturer and request they honor the warranty. They'll generally (if you talk real sweet to them) honor the warranty within the same month it goes out. If they resist, either ask to speak to a manager or write a letter to the office of the president of the company. Four days out of warranty shouldn't prevent you from getting a replacement.
David Breth
>I've had warranty experience like that as well (where they extended it for the sake of human decency).
Mark Wollschlager
>The warranty on hard drives is often longer than that of the system.
If all else fails ( no pun intended) you might contact the disc vendor. Some of the harddrive vendors have an online system to verify the s/n of the drive and give you replacement info.
mark.
Two hard drives
Wayne Cease - Atlanta
>I bought a second HD for my PC after I lost two on other machines in a two week period. I back up my data to the second drive; the OS and programs can be reloaded from their original CDs. If you watch there are often sales for HDs. I think I got my 80 GB HD for $20 after rebates.
I'm looking into building a 1+ TB (that's terabytes) RAID 5 server for our home. A RAID 5 server means that we won't have to back-up the data; or at least not as much. You can lose one drive and not lose data. You have to lose two or more drives at once.
I use a 5 Mp digital camera, bought a 7 Mp camera for my wife for xmas this year (shhhh), and the kids have older digital cameras too. We also bought the kids a Mattel Vidster (low resolution QuickTime video camera for kids), and at some point the kids will get better digital cameras too. All of this digital media takes up a lot of storage space. My pictures average around 2.5 MB each, and the tests I ran on my wife's camera (to ensure it worked before a Christmas morning disappointment) show that those pictures will be around 3.5 MB each.
DVD's, even the dual layer versions, just don't back up enough data for this. The dual layer discs are still a little pricey, and I already need 3 single layer DVDs just for my photos, and another one for other data files and down loaded software.
I've also run into having files on the kitchen computer and my email set up on the one in my home office. So, having a network RAID server would allow us to store everything that we want backed up or shared there.
Now I just need the time to get around to doing this before we lose too my data.
Re: Two hard drives
Carole in VA
>This was my slave drive and it WAS my backup drive. Bought it new for that very purpose. :( We should all be cognizant of the fact that most of the HD manfacturers have cut their warranty periods from 3 years to one year. What does that tell us?!!! The demand for size and speed has driven down the quality and life expectancy of todays hard drives.
Re: Two hard drives
Stuart Johnson
>I've been using one of those little key chain things that plug into a usb port to back up my data. I'll probably be up a creek if (when) my hd finally goes. Most of my applications are a mish-mash of upgrades furnished by the company where I used to work. I worked from home and from time to time they would send me a cd and have me install whatever it contained. For all I know I probably have some upgrade from Dos 1.1.
Re: Two hard drives
Mark Wollschlager
>You might buy a seagate, all their drives have a 5 year
http://5yrwarranty.seagatestorage.com/?elqPURLPage=540
mark
New drive on the way!
Carole in VA
>They have a 30 day grace period on the warranty. ;)))
Ghost!
Ron in Drums PA
>Carol I feel you pain!
At my business I have a raid that works great but at home I go a different route.
There is a program called Ghost that will make a complete copy of your harddrive to a second harddrive. With the price of hard drives these days, this is cheap insurance. Of course if you do crash, the backup harddrive is only as good as your latest backup. But at least all your programs and files to that date are there, I can copy a 160 gig harddrive in about 30 minutes. Also, you do need to remove the backup HD from the system before you reboot. MS doesn't like to see two versions of windows available.
BTW when you buy Ghost 2005 you will find another program called Ghost 2003. Ghost 2003 works better than the newer version. Maybe that's why it's on the CD.
Eddie Severt
>Carole, this may be a long shot, but the computer repairman for our Board of Education told me that if a hard drive was about to go out to try this trick to get all of the info possible off of it. Put it in the freezer for a couple of hours and then hook it up immediately and try to remove the data. This apparently shrinks the bearings, etc. and may let you recover most that was stored on it. Won't work every time, but it can't hurt. Good luck, Eddie
Carole in VA
>Thanks Eddie. I was able to recover almost all of what I needed using using a recovery utility.
Juergen
>That technique was used in the old day when the bearing would ooze lubrication and the platters wouldn't spin up. Cooling the ooze would allow the drive to spin up again, sometime long enough to transefer the data. The bearing used today don't have that problem.
