flooring cut nails
Lan Brady
>I just bought a box of flooring cut nails. I was unable to drill a hole in it. Are these hardened steel?
Lan
flooring cut nails
Lan Brady
Lan
Re: flooring cut nails
Brian Hahn in SW Wisconsin
>They used to be and sounds like they still are.
Back 20 or 30 years ago, before they came out with round concrete nails, cut nails where what we used to nail into concrete. Plenty hard, but kind of brittle - snapped more than one with a poor hammer blow. They were hard enough to dent the face of the hammer. I've still got some small carving tools I made from cut nails.
>They most definitely are. I use them in my tool making demos. Heat them cherry red and let them cool slowly and then you will be able to drill them.
Re: flooring cut nails-Thanks
Lan Brady
>John,
Thanks, it never ocurred to me that they would be hardened. I thought my all my drill bits were dull at once.
Now, I can drill the holes plus a new source for metal to make tool. What tools do you make in the demo?
Thanks, Lan
>When I use the cut nails I usually make either miniature hollowing tools or hook tools. Mostly I like them because I can break one, anneal it and bend it, then harden it and break it. It makes it very clear how the heat works. Usually now I just do the heat demo with the nails and then I use a piece of drill rod to make an ornament hollowing tool.
Traveling celebrity
JKJ in East TN
>Hey Sir Lucas, would you come back and give that demo to Smoky Mtn Woodturners this spring/summer? I learned a lot from your skew chisel/hand mirror demo.
