Hey Carole! another source of drill rods...
Jorge Castaneda
>I just thought that the fastest and cheapest source of drill rod is your local hardware store, just buy a couple drill bits, cut the flutes with the grinder, sharpen to the right shape, and you are in business.
Jorge
Re: Hey Carole! another source of drill rods...
Carole in VA
>Thanks, Jorge, but I ordered some from Enco today...12 blanks for what my local HW store would charge for 1 drill bit.
Yes, But...
Jorge Castaneda
>The rod you get is soft, it has to be hardened and tempered before you can use it.
heat treating..
>If it does send me an e-mail and I'll send you the instructions. Takes about 2 minutes or less.
Re: heat treating  *LINK*
RussFairfield
Making your own turning tools
Re: Yes, But...
Carole in VA
>Arrrgh! How can I tell if it has to be heat treated? I ordered #891-4383 from Enco.
Re: Yes, But...
>Those are what you want. They are fully hardened High Speed Steel. Note that the catalog states that they can be easily modified as punches or cutting tools.
Re: ...and
>If they needed to be heat treated, the catalog would say "fully annealed".
You can't heat-treat HSS in the home shop
Ken Grunke from SW WI
>Carole, I hope you ordered rods that are already hardened, but the Enco catalog listing for what you ordered doesn't say.
When you get them, drag a file across a piece. If it just skates across and doesn't dig in, then great. If the file bites into the metal at all, then I would send them back in exchange for part #383-7005 --HSS round cutter bit, 3/16" x 3 1/2" long--these are definitely hardened.
Should have just called Don!
Carole in VA
>With my concerns about shipping the little replacement bits for my Stinger hollower...he would have taken care of me and kindly offered to do so last night, but I had already ordered the drill rod. That's what I get for not wanting to bug someone.
No need to
Bob Hackett(Mainely,Bob)
>You can heat HSS to red heat(and bend it)and when it returns to cool it will only have lost afew points of hardness.Plenty hard for turning and still harder and more wear resistant than HCS.
MB
Re: Don't confuse drill rod with drill blanks.
Al Crandall (NE of Indy)
>Drill rod almost always comes from suppliers like Enco in 36" lengths and will be soft. It will be marketed as O-1 or A-2 or W-1. These are not HSS but are servicable in a lot of instances after hardening. Do not get the cutting edge blue when sharpening these steels.
Carole, what you bought is exactly what you needed. It is marketed as a drill or reamer "blank", and is M2 HSS, fully hardened and centerless ground to close tolerances. Don't feel bad because you were confused. You don't have a background in tooling. The suggestion to use the shank of a drill is questionable in my opinion. Only the flute area of drills remains hard after manufacturing. The shanks are drawn back in hardness so he drill chucks will grip them better. A drill's shank is easily scored by a file or the jaws of a chuck if you get much past the flutes.
the bright side...
>Carole--
As confusing and frustrating your quest for the best deal on these toolbits is, some day you'll be able to help someone else in the same dilemma.
The distinction between drill rod, drill and reamer blanks, and cutter or tool bits is not very clear in the various catalogs we've looked at, except for the McMaster-Carr catalog. I spent some time trying to sort that mess out, so I could give you a solution and also to satisfy my own curiosity--not trying to make you feel guilty or anything.
What you need for your hollowing tool, and any woodturner's hollowing tool that takes small inserted bits, are HSS cutter bits or HSS tool bits--"bit" is the key word, which designates something which is hardened and ready to use for cutting metal or wood (after grinding the tip, of course). "Cutter" bits and "tool" bits are just two ways to describe the same thing in this case. These are originally intended for metal cutting, but the woodturning community has adopted them for our purposes and they do very well.
So, always look for BITS whether cutter bits or tool bits in the catalogs, NOT drill ROD or BLANKS which may or may not be hardened.
Hope this clears up some of the confusion, and helps avoid the high markup by your hollowing tool's manufacturer.
Thank you, Al!!! Whew!
Carole in VA
Don Pencil
Don Pencil
>Al is correct.
