Product review: Dynamitt Sanding Glove *LINK*
Mike Schwing from Md.
>I received a complimentary "Dynamitt Sanding Glove" in the mail recently. A letter was enclosed telling me that it had been sent me free to use and review and pass my thoughts along to my turning club, which I figure that means you guys/gals. (Plus the Baltimore Area Turners)
It is a canvas "mitt" with a large piece of velcro on the palm side and a rubber insert used to stiffen the palm area. Also enclosed are several of each grit from about 60 grit up to 600. Nice assortment actually, but missing a jump from, IIRC, 180-320.
I used it today on a large 16" black cherry bowl.
I was unimpressed, completely. The very first time I removed a piece of sandpaper from the mitt, the 120 grit, the velcro backing on the paper separated, making that piece unusable again. Same thing happened on the next piece of 120 grit.
The mitt works as advertised, but it is very large and clumsy. I have average sized hands, and they get totally lost in this thing, making it impossible for me to "feel" my way around the surface being sanded. I used it both on the interior and exterior of this bowl and found it to be less useful than power sanding, but a little better than holding paper by hand. I was a bit worried about getting it too close to the chuck as well, so I could only use it on a small portion of the exterior of that large bowl. On the interior, it is possible to use the stiff rubber insert to advantage to smooth out any profile errors, but it is impossible to avoid the typical sanding scratch marks that occur when power sanding.
After using it to go up to 180 grit, I decided to abandon the thing and go back to power sanding with 3" discs. No scratch marks, easier to feel what I'm doing.
This might be more applicable to spindle sanding, but I don't do spindle turning, so I couldn't judge its worth for that.
I think a smaller, more form fitting version WOULD be useful. I like the removable rubber insert, but the large clumsy mitt was more like a mop.
I'll be passing the demo model on to another club member next week and don't think I'll add one to my collection. But I appreciate the opportunity to evaluate it.
Here's one place on the web I found this product...
Dynamitt
Re: Product review: Dynamitt Sanding Glove *LINK*
Rick Allen
>Thanks for the review Mike.
This is a rip-off of Bruce Hoover's sanding glove. The "sanding glove" does nost of the things that the "sanding mitt" fails at. It fits better and is availble in different glove sizes. The velcro is on several fingers, both sides. The idea being that you can use the glove without cramping your hand for "HAND SANDING" oporations. The glove is specificaly NOT for sanding with the lathe running.
I don't have much problem holding onto a piece of sandpaper so I don't use or own a Bruce Hover sanding glove.
Not only is the sanging mitt a ripoff of Bruce's idea the poor execution of the idea degrads the precived value of Bruce's product.
Sanding glove
Jerry Whitaker
>I got the same kit in the mail a few days ago but have not tried it and don't intend to. I put the mitt on my hand attached a sheet of sandpaper and immediately discovered it was not for me....toooo stiff and bulky and a couple of the backings were separated from the paper right out of the package. I do not believe the thing is flexible enough and is totally unappealing. Like Mike, I will pass mine on to "Someone Who Cares".
James McClure
>How many of these things did they send out????
I got one too and it's still in the plastic wrap. I don't think they intend you to use it with the lathe running. From the looks of it, I echo the comments that it seems uncomfortable, stiff and klunky. I will probably take it to our club Christmas party and give it as a door prize.
