Sandpaper storage advise
Stokes
>What methods do you use to store your sanding supplies? I have discs in several diameters and multiple grits. I can not seem to be able to decide on an acceptable method for storing. Right now 1/3 of my bench is taken up with sandpaper storage!
Please advise,
Stokes
Re: Sandpaper storage advise
>For the big sheets? How about a "file box" with separators. For the 2" and 3" pieces? I use a couple of 3" x 5" file boxes that the LOML picked up somewhere. For the 5" random orbital, I have an old 5 1/4" floppy box that works nicely. They go on one of the shelves in my shop.
Re: Sandpaper storage advise *LINK*
Mike Cunningham (Cape May)
>For sheets: I built dividers into one of the shelves in a wall hung cabinet. I used lauan for the dividers, leaving approx. 2" space between them. Each space holds a specific grit; 120, 150, etc.
For 2" discs I have a storage device that Craft Supply sells, it contains 6 or 7 bins that tilt outward each olding a specific grit, this too is mounted on the wall.
For rolls, I mounted a length of 1/2" pipe with a pipe flange at each end. This is suspended from the ceiling with two pipe hanger straps, one at each end. The rolls are on the pipe in grit order. I attached a small spring clamp to the end of each roll and these hang just above head height. Just pull down and cut off a length.
The link shows the storage bin for discs.
Tilt-a-bin
Raymond Overman in SC
>For 2" discs I use an 18 drawer plastic box with clear plastic drawers. One drawer per grit.
For sheets I use a hanging file and made a vertical hanger on a wall with two pieces of scrap wood appropriately spaced and indexed with holes. One folder per grit.
David Breth
>I had the same problem, and just solved it with regular old file folders. My method is pretty ho-hum, but so far it is working for me.
I stuck each grit in a file folder, and the folders are stacked on the far corner of my workbench. Small pieces and large pieces are kept there, smallest pieces on top. So, I'm working on a bowl and it is time to sand. I choose my starting grit, and work my way through the folders, right up to the folder labeled "paper bag". All my sanding is by hand, so I don't have to worry about segregating particular sizes/discs, etc.
It ain't elegant, but it works. Since I did this, I haven't had to hunt around the shop for sandpaper once.
David B.
Rick Allen
>I use a tackle box with 10 dividers in it for the discs. One box for 2", one for 3" and one for extras and mandrils... The tackle box sit on my lathe when I an sand so I can easly go through the grits. It closes up and be put out of the way, flat or on end. The tackle boxes are stackable if I want. I think they cost about $7 each and are about 10"x12"x4".
JKJ in East TN
>Same here, the plastic tilting bins for disks (available from HD here), a long dowel with thin ply spacer disks for the rolls, and a file for sheets. BTW, for the finer grits (400, 600), I cut sheets into small strips about 3/4"x2" and store them in the bins with the disks. I find these great for finish sanding on small spindle turnings, often all the sanding these turnings need.
Dick Hines
Dick Hines
>Go to a sued office supply store and get the plastic in-out boxs they will hold loads of paper. I got lucky though. Our office was down sizing and was throwing out the old boxs. I have enough for all the grits I use. 60-1500.
As far as the disk I only use 3" disk so I don't have lots of sizes to consider. I useily just leave them in the pack they come in and stack them in the top of my tool box. Not to neat but works for me.
Randy Miller
>Pretty much the same as others with regard to mass storage; file folder for the sheets. For the rounds, I don't have the tilt'a'file, but use a parts divider for HD.
Also, since I hate having to fumble with the bins when I'm sanding, I keep a long 1 inch wide velcro "hook" strip stored in it's own bin. This strip has a single pad from each grit in order so that when I'm sanding I can just progress through the grits without having to keep accessing the mass storage. Mark the location of each grit on the strip so that if/when you misplace a circle you know what to pull from the bins.
I also keep a small adhesive "loop" section on the headstock so I can attach the strip directly to the front of the lathe so grit changes are quick and easy.
Good luck!
Randy
>I bought a 15 bin organizer box at Lowes. The top nine tilt out bins are smaller and I keep the two inch stuff there and the three inch in the bottom six. I wrote on the front of each drawer the grit, with a magic marker. The sanding disks fit in the drawers also. Works great. I tuck the used disk back in the crack at the front of the drawer and use it until I throw it away.
I made a set of shelves for sheets. I used some scrap 1/8 plywood I had for the shelves (it was a "door skin" available from Home Depot) If you make one, make it big enough to hold 9 by 12. A lot of sand paper is not 8 1/2 by 11.
FWW or somebody had and article on storing sand paper and they guy made a rake with pull out shelves for a ROS. He actually put a set of dowels on each shelf that matched the holes in his sandpaper, either five or eight, which ever he had. I thought that was really anal until I realized why. He put all the sand paper, each grit to it's own shelf, face down. When he wanted to load the sander, he just stuck it onto the dowels and pick up a sheet. Imagine that! perfectly centered every time. I may have to do it. Right now, mine are just in the drawer with the sander. Three dowels each would be enough. Round off the tops.
Brian McKearney
Brian McKearney
>I also use one of these 6-compartment bins - you can find them at Home Depot if you have one local. I stuck a little 3/4" square of velcro on the front of each bin so that I can keep the 2" sanding disc that I'm currently using stuck to the front of the bin (one bin per grit). Keeps the discs handy!
Brian
JKJ in East TN
>that I'm currently using stuck to the front of the bin...
What a great idea! Far better than my method of saving the current disks on the lathe bed, on top of the headstock, on the floor behind the lathe, in my shirt pocket, ...
Doug Trembath
>I helped a lady move a bunch of stuff (LOML's friend), and inherited a bunch of cool storage pieces. I use a card file drawer set, sort of a miniature steel filing cabinet with a sliding end stop. I have two that have four drawers each. I have one at the lathe, and one in the finishing area. I recommend using 1/8" hardboard for separators, making it easier to keep stray grit under control, and easy to locate the grit you want. Plus, chips just fall off the face of them, (except for the handles, but they break right off when you grab it), no buildup, something that every turner can appreciate. One drawer holds up to 220, and the other holds the rest, with a generous area for slightly used and specialty disks behind that. Two more drawers to hold extra accessories and junk. It's really convenient, and works really well.
Best of luck...
Doug Trembath
Studio in the Woods
Sanding's a necessary evil, and as you experience some of the pitfalls, you pick up certain habits, if you want to survive. Keeping the stray grit thing down has been my pitfall more times than I'd like to recall, so think about that in your decision making. Good luck, whatever you choose.
Doug Trembath
Studio in the Woods
Stokes
>Thank you all for your input. I think the tilt-a-bin solution is just what I am looking for. I especially like the idea of using a velcro strip that a couple of you mentioned.
Thank you again,
Stokes
Down East solution
Bob Hackett(Mainely,Bob)
>Go to the fish market and get those plastic bins they sell for .10 each(the ones they get thier fish fillets in from the docks).Label each on the end with the grit size.After you cut the discs from the yard wide hook and loop paper you got at a discount from Industrial abrasives just place the discs in the appropriate bin and stack them one on top of the other on the bench,be sure the coursest grit is on top.Work thru the grits and as you finish with a grit place it on the bottom of the stack.When you finish with micro fine beartex you`re done and you can put a lid on the top bin to keep the chips and dust out.Place the nested stack on the shelf till next time.If you make the shelf a tight fit for the stack the discs will be held flat and sealed against moisture.
An added tip is to fix a strip of velcro to the lathe ways(or overhead) so you can stick the discs there in the order they were used in case you have to go back for some reason.
Other than the Milwaukee/Sioux ergonomic drill and the Irwin 1/4 bit extention for deep forms that`s about it,for now.
Mainely,Bob
