Cold -vs- warm wood
Cold -vs- warm wood
Cold -vs- warm wood
Pete in Holland, MI
>Tis winter here in Michigan now (in the 20's most of this past week). Bowl turner "on the learn" here. Have you green bowl turners found it easier on the wood to bring it in and allow it to warm up to the house temperature, or is it fine its cold state to rough turn bowls from ? Have some wood with sentimental value that I want to reduce any risks in the bowl making process.
Many thanx !
Re: Cold -vs- warm wood
Steven Antonucci
I think freezing is a way to "dry" wood.
steve antonucci
>I keep my "log form" outside, and my roughouts are stored in the heated garage. No rhyme or reason, just how I do it.
Steve
Ron in Drums PA
>There was this elm tree that was cut down last January in about 12 degree temps. I found the logs after a week or so of sitting outside and they where frozen solid.
I chainsawed a couple of frozen blanks with no problem.
I found that frozen wood bandsaws quite well. Better than "warm"or dry wood anyway.
I mounted the first blank on the lathe and it turned with only one problem.
Those nice long curls of frozen wood HURT!! It was like getting hit with a high powered, automatic pellet gun!
I had to wear gloves and put on few more layers of fannel shirts to help cushion the blows.
Other than that it was a breeze!
David Breth
>Pete -
Just a suggestion that you might want to wait a little while before you turn this particular wood (sounds like you are kind of new to turning). If you're dealing with wood that has some sentimental value, you'll want to have a certain amount of experience behind the lathe before you chuck it up. I've been turning a little less than a year, and am just now confident enough to do that kind of thing - in fact, I've been collecting pieces of wood from various places of family history to turn. Earlier in the year I would have been too low on the learning curve to make a piece I could enjoy long term. Just in the last month or two I've gotten my skills to the point where I'm far less likely to destroy a piece and far more likely to finish with something I'm really happy with. I've saved a few pieces of wood that I just liked for a time when I could turn them well.
Hope you don't mind the input.
David B.
Bill Neddow
>Up here in Ottawa, Canada, I turn a lot of frozen wood -- and I prefer it. I am not knocking summer, mind you. It is just that frozen wood seem to cut easier and cleaner. Good idea to wear a thick shirt, though, because it gets cold as the shavings sticking to you start to melt.
My son's dog also found out about the cooling effects of nice frozen shavings. She had long hair and was a little too warm in our house in winter. So she would sneak out under the lathe without me seeing her, and stand there in the shower of shavings until she had about six inches of stuff on her back. Then she would wander back into the Family Room. When it started to melt, she would shake it off. I usually found out about this when I hear the scream from my wife.
Pete in Holland, MI
>Many thanks !
Turning talents are getting pretty good. Just wasn't sure if frozen wood created another undesireable variable or not.
Pete
