We value your privacy.
>Is it worth it - well, it depends. It is very good for spindle turning. Especially if you happen to have to take a spindle off and put it back on again. I am contemplating getting a revolving one for the tailstock to complement the one in the headstock. You say you are turning bowls and mallets. I don't know if it would prove to be that useful in your applications (especially the bowls).
>I'm a little iffy on mine. For spindles it't good unless they are small spindles. Then the pressure from the springy point is too strong and makes the spindle chatter easier. For bigger spindles I like it but can't say it's that much better than the 4 prong drive center that I've had for years. I've looked hard at the new revolving center but don't see how it offers much that my cup centers don't. I do think they would be great for some offcenter work that I do but it would cost me $150 do by both a larger drive center and the live center. I've been doing this turning without them for years so I don't think I can justify the money.
>It is my favorite center for spindle turning. I have two sizes but use the smaller one more.
The center spring is in fact quite stiff. For thin spindles, I always make a small hole in the end. This takes only four seconds with a gimlet I keep stuck to the front of the lathe with a magnet. (I also make a hole in the tail center end.) The holes center the work and keep the thin wood from splitting when the tailstock is tightened.
>I have two sizes and I use them both all of the time. I use the 3/4 inch one to start just about everything. I am limited to maxium turning of about 12 inches so I don't know how it would work with larger project, but I have used mine on some really out of balance turnings without loosing any of them. I will buy the buggest one after the first of the year and then the revolving one next summer. Just my opinion.
>HI Curtis, I have several students who use(d) the stebcenter because of their fear of catches, esp. with the skew. With good technique, I don't see the need for them.
>I like the Stebcenter for all my spindle projects. I, too, found that the center spring was too stiff for very thin spindles so I took the factory spring out and replaced it with the spring out of a cheap retractable ball point pen. I think I had to cut the spring shorter. Works great; for spindle stuff only.
Are you confusing the Safecenter with the Stebcenter? My students use the Safecenter(actually a cupcenter in deadcenter form used as a drive)for skew work because it stops rotation when they get a catch.
The Stebcenter holds as well as any spur center I`ve ever used.It just allows you to load blanks without turning the lathe off(spring loaded center point) and is far safer that a spur center if you contact it with flesh(no sharp spurs).
>The idea behind the spring loaded pin is so you can change out workpeices (spindles) without turning the lathe off. I saw Nick Cook demonstrate this once. To put a peice on, you just rest it on the tip of the Stebcenter and tighten the tailstock until it engages teh teeth. After the spindle is finished, you back off the tailstock unitl the teeth no longer engage.
>Curtis, I don't have time right now to read all the responses so pardon if I am repeating. If nothing else, the Steb center is an excellent tool for learning to use the skew chisel as it allows you to experiment and learn the proper technique without horrendous catches.
