Where to get HSS drill blank?
Carole in VA
>I wanted some relacement bits for my Stinger hollowing tools, which are 1" x 3/16" round HSS drill blanks. When I went to order them, shipping on one little blank was $10 and something (the blank was $5 and something) Shipping on 4 of them was almost $14. I really can't see paying that much in shipping for 4" of 3/16" drill rod. I am wondering if there is somewhere I can get it in longer lengths and just cut it myself?
Re: Where to get HSS drill blank?
>Have you checked with ENCO. the shipping might be high but I bought my last 3 foot section of drill rod for less than $1 if I remember correctly. Is this 3/16 round rod or 3/16 square HSS bits. If it's 3/16 HSS square I believe I have some I will send you. I'll have to look and see if I have any left. I bought 10 the last time I ordered and got them really really cheap.
Will I be able to cut this to length?
Carole in VA
>I have found something at McMaster-Carr. What does it take to cut this M2 stuff to length? Can it be done with a hack saw?
ASTM Specification ASTM A600
Drill Bit Style Drill Blanks and Rods
Drill Rod Type Precision Ground
Drill Bit Composition Grade M2 Air-Hardening Tool Steel
Surface Treatment Unpolished (Mill)
Overall Length 36"
Specifications Met American Society for Testing and Materials (ASTM)
Cutting HSS bits
Fred in NC
>The easiest way to cut a piece of HSS from a rod is to grind a V around it. I use the corner of the grinding wheel. Then put it in a vise and snap it off. CAREFUL, WEAR EYE AND FACE PROTECTION. Then grind it to shape.
Re: Where to get HSS drill blank? *LINK*
gtwilkins
>Carole, Don't know if this is any use to you for tool making.
http://www.dixiepins.co/prod_hub.htm
Look at the Dixie pins, they come in every size, I have been going to ask if the toolmakers here if this stuff would be good for things like 3 point tools and what evers?
They also have metric end mills that might be of some use to pen men.
Trevor
Dixie Pins
Steven Antonucci
I use a dremel and a cutoff wheel
steve antonucci
Re: Will I be able to cut this to length?
Ken Grunke from SW WI
>Carole, the stuff you're looking at in 36" lengths may not be hardened. If it says somewhere "in annealed condition", they are not.
Here's what you need, fully hardened M2 HSS drill blanks--enter this number in the search box:
3009A123
You can't cut this with a hacksaw, need a cutoff wheel which you can get for a Dremel, or for a 4 1/2" angle grinder, even a skilsaw. It's a thin, reinforced grinding wheel for cutting hard materials. The different types and sizes are available at most good hardware stores.
You can also just notch it on the corner of the wheel of your shop grinder, and snap it apart.
That search number is for McMaster-Carr, BTW
Carole in VA
>Ken, the stuff I was looking at is 88995K17. What does annealed mean? Why is this so much more expensive than the part# you gave me? What does it mean when it says M2/M7 (the part you gave me)?? I thought it was either M2 or M7. I'm feeling like an idiot just trying to get some simple drill rod to make bits with! All this steel grade stuff is confusing. :(
>Carole, the 3 ft. rod is actually cheaper per inch, but I found out that it is much softer than the short drill blanks I pointed you to which are 3 1/2" long. Took me a little time to figure that out, but the hardness of the two products are measured on different scales--Rockwell B100 for the 3 ft stuff, and Rockwell C64 for the other. C is used for hard tool steels, and B is for softer, anealed (unhardened) steels. Now, to really confuse you, the higher the number, the harder the material. But these are different scales, and if you take a look at a conversion chart here:
http://www.gordonengland.co.uk/hardness/hardness_conversion_1m.htm
You'll see that Rockwell B100 is way down on the same line as C23!
C64 is about right for HSS tool bits for general use, that's probably what your original bits were.
I'm not familiar with the M7 designation, but it appears to be interchangable with M2 so you'd get either one or the other.
Now, if you're not set on ordering from McMaster-Carr, you can get these bits for about 60% of MC's price here:
mscdirect.com
Enter 01102128 in the search box, select "MSC Part #" for the keyword. Here the price is comparable per inch to the 3 ft stuff, but in 3 1/2" lengths and identical from what I can see to what McMaster-Carr has.
Re: $0.84; $1.51; $2.19; Take your pick.
Al Crandall- NE of Indy
>Carole, three sources you should always check for tooling needs are:
www.use-enco.com
www1.mscdirect.com
www.mcmaster.com
The three prices I quoted in the title line are for your 3/16 drill blanks (not drill rod) from these three sources. The stock numbers respectively are:
891-4383
01100122
3009A-123
Shipping charges
Fred in NC
>I deal with the sources listed above. I have found their shipping charges to be most reasonable. The only time the shipping seems to be expensive is when I place very small orders, which I avoid by combining orders as much as possible.
It would seem that a very small item like a tool bit could just be put in an envelope and sent first class for 37 cents, but these companies are not geared to function that way.
Too bad I don't have any in that size, or I would just send you a couple.
Incidentaly, ANNEALED HSS was mentioned above. This is not a good material for us turners. The hardening process for HSS is beyond the capabilities of a home shop, and commercial heat treaters have minimum charges that would make it economically impractical. Tool bits are already hardened and can be ground to shape, so they are a better material.
Drill rod is another story. Both O-1 oil hardening and W-2 water hardening are easy to work with. W-2 is a little harder as it comes from the mill, and for smaller tools can be used as is after grinding. Hardening only requires a propane or MAPP torch. However, for a hollowing tool HSS is the right choice.
What annealed means
Rick Allen
It means that the steel is soft. Soft steel can be milled, bent and otherwise machined to the desired shape and size. Once the steel is machined it needs to be hardened and then temper so the hardness and edge holding properties we admire in HSS can be realized. Once the temperature is reached the steel is quickly cooled (some HSS is air cooled, some is water cooled, some is oil cooled I imagine that there is some HSS which is specified to be cooled in some other way) which yields a very hard but brittle steel. The temperature required to harden M2 steel is beyond the normal home shop to achieve. Tempering requires a specific sustained heat followed by a slow cooling to reduce the brittleness of hardened steel. If you temper the steel at to high a temperature you could end up with an annealed form of the steel.
We prefer not to use files for turning tools because files are hardened but not tempered (or at least not tempered very much).
Good Luck
Richard
O1
Jorge Castaneda
>Carole,
All you need is O1, it comes anealed, (soft). so you can cut it with a hack saw, them you have to harden it,heat it to red and quench in peanut oil, clean it so it is shinny again and then temper it by heating to dark straw, (just before the purple) and quench in water. Voila!
I just did all that today.
My suff is dril rod, round.
How much you need? I have more than I need. Let me know.
Jorge
