Sharpening?
Sharpening?
Sharpening?
George (Oxford, NC)
>Well I bought the HF lathe I mentioned in an earlier post. I will be taking a sharpening course at Woodcraft next month as well as a basic turning course. But in the meantime, while I'm futching around with an inexpensive set of HF tools, I started wondering. I don't have a 'good' grinder, just a 6"er that I used for drill bits and metal work. I know that I will have to get one at some point in time (probably soon) but in the meantime I am using something else and it seems to be working. I have one of the cheap Delta 1" belt/6" disc sanding stations. I put a fine grit belt on and have run the gouges, etc. across the belt (on the flex part, not the part with the platen behind it). It seems to give it a good edge. At least I can tell the difference between before and after I touch it up on the sander. Is there something inherently wrong with using the sanding belt?
George
Re: Sharpening?
Re: Sharpening?
Bill Howatt
>Nope, it is one of the ways of sharpening lathe tools and other things for that matter.
Like the guy I used to work for said, "You can't argue with success!".
Bill
Re: Sharpening?
Re: Sharpening?
>George I sharpened my turning tools for years on a sears 6" grinder with gray wheels. Then I finally decided I needed a better way and I switched to using my 3" belt sander. Eventually I got an 8" grinder with white wheels but I've sharpened on gray wheels when in friends shop and don't have any problems. It's more a matter of technique and skill than what you use. That being said it certainly is easier, especially for the inexperienced to sharpen on a grinder that doesn't vibrate with cool running wheels and a sharpening jig. Use what you have now and have fun. Then as you learn more save up and buy a better system.
