Anyone using wood and acrylic segments together?
Dave Smith, Longview, WA
>I am making bracelets for Christmas and I am thinking about using some acrylic pieces with wood to make some bracelets. Bad idea or can I get the two materials to play nice. I figure I will need to use thick CA for wood to acrylic bond.
Dave Smith
Wondering why I can't be satisfied with plane old wood in Longview, WA.
Re: Anyone using wood and acrylic segments together?
Paul Tacy
>Dave,
I have turned a couple of small bowls using Lexan and wood (cherry) bonded together. I did use medium thickness CA glue as you suggest, and it worked just fine. I was hesitant to try acrylic due to it's brittle nature. Afraid it might shatter on the lathe. Someday I probably will don the full face mask and give it a whirl (no pun intended). Check back if you try it.
Re: Anyone using wood and acrylic segments togethe *LINK*
Mark Kauder, Phenix City, AL
>Dave,
As you correctly surmise, the right glue is the answer. I would suggest either epoxy, to a lesser extent CA, or believe it or not Hot Hide Glue.
Hot Hide glue will stick to most anything, give the right gel strength. It is a great cross-material glue. Some of it is used to etch glass.
This link will give you great info, and point you in the right direction.
Mark
http://www.frets.com/FRETSPages/Luthier/Data/Materials/hideglue.html
Specialty glue
>In the old days, I used to make light fixtures and lampshades by veneering on Plexiglas. At the time, a plastic fabricator steered me to a three part adhesive called PS-18. (It is a relative of PS-30, for those of you who bond acrylics frequently.) It was the worst smelling stuff you can imagine but worked great. You might have to contact your local plastics mart and find out if anyone still makes such an adhesive.
Ellis Walentine, Host
>I've glued acrylic and other plastics to wood using epoxy. I always sand the surface with 120 or 150 to give it some tooth for mechanical bonding.
Sounds kinda scary to me.
>Hi Ellis,
One thing I don't need to do is spend money right now. Besides the stuff sounds lethal. I am going to try CA glue and it doesn't work I'll just skip the wood/acrylic joining for now.
Dave Smith
Two bracelets down and 6 to go in Longview, WA.
Rick Allen
>I have used epoxy (west system) to bond "chrushed velvet" to a cocobolo bowl rim. That bowl was gifited 5 years ago and I hearda few days ago that the bond was working fine.
RK in Milw
>Funny you should bring this subject up. Downright weird. I was thinking of doing that very thing last night only with a finial for a hollow vessel. I just finished it and will try and post a photo tomorrow. Thick CA worked great with acrylic and ebony. Time will tell if it holds.
Ric Taylor
Maybe try some of the flexible CA glue?
Ric Taylor
Jeff
>Dave,
I have turned maple with Corian (which is acrylic) and did not have any problems, that was a few years ago and it is holding up fine. I can't remember what CA I used. I posted a pic of it a month or so ago, titled "Any Ohio State fans?" If you can't find it and want to see it let me know and I will post it again.
Jeff
