Woodfast Lathe will not start
Michael Wilkins
>Recently purchased a pre-owned Woodfast lathe,Model 410. Well built machine, heavy in all the right places, but it will not start. Put a new plug on to match the twist-lock outlets and hit the green button. Checked all that a non-electrician can check and all looks OK. Just a click from the electrical box. If any one has such a lathe or can offer help, I will forever be in your debt.
Re: Woodfast Lathe will not start
total shot in the dark
Mike Schwing from Md.
>Occasionally I freak out when my PM3520 won't start. Every single time it turns out to be that I have the speed control turned all the way down. Glad I've always caught it before calling someone in.
Another total shot in the dark
Bill Howatt
>If it is reversible variable speed with a center off postion on the direction switch make sure the switch isn't in the Off position.
Bill
Speaking of Outside Shots
>Check your Red Muchroom kill switch. If it got bumped and not reset, you can push green 'till next month and still get nowhere.
M
[It's embarrassing as hell, DAMHIKT]
*Mushroom*
Molly Winton
>I have a Woodfast M-410 also. I've had a similar problem caused by dust getting into the interior switch and interferring with the connection. I got a replacement switch from CS, but due to my lazyness I've yet to change it (am told this will prevent the problem completely once done). In the meantime I bang on the red off switch a few times to knock off the dust, then hit the green button and it starts right up. Don't know if this is your problem, but worth giving it a try.
David Breth
>Now that is a response even I could deal with. I've got lots of stuff in the shop to hit things with.
MFoster
>I have an loder woodfast lathe that I purchased from craft supplies. When I bought mine, variable speed controls were just coming on the scene. I purchased a machine equipped with the variable speed controls. I wound up having some problems with the controls several years later, and contacted Craft Supplies. I then found out that they imported the lathes from AU sans motor and controls, and installed these components themselves. My lathe has a DC motor with a box inside (Under the bed) that houses the electronics. I also found out that the controls for the motor were put together by a turner in WA who happened to know a lot about electronics. His name was Denver Ulery. I contacted him and he was more than helpful. I sent him my controls, and he fixed the problem for a minimal charge. Unfortunately he passed away a couple of years ago, so if your controls were made by him, you'll have to find a electronics whiz to help you diagnose and fix your problem.
Re: Another total shot in the dark
>Some mechanical variable speed lathes will only start when they are in the slowest setting. On lathes that are old you may have to fiddle with the lever to make it actuate the switch that keeps you from starting the lathe at high speed. I don't know if your lathe has that or not. I've only seen this on lathes that came out of High School shops.
Dinyar Chavda
>Michael:
The click from the electrical box usually means that the switches are working ok.
If the above suggestsions don't work, it may be that one of the fuses might have blown. If you look at the box which houses the electronics(usually attached to the inside of the body under the ways) and remove it from the lathe, you may see two fuses (mine are under two plastic screws on the side). Check them out to see if they are fine.
Also, in my Woodfast, there is a loose connection somewhere in this box that would cause the lathe to stop, until I shook the box. I could never find it, not could the folks at CS. Now the box sits on the floor, and (fortunately) does not give me any problems. Try shaking yours (gently) to see if that gets it to start.
Another shot in the dark
Scott Hogsten
>It's not three phase is it ? Do you need an inverter ?
Scott
Michael Wilkins
>An electrician friend is going to check out the control box, before I mail it to Craft Supplies. One of their tech guys says it sounds like a problem inside the control box, since this is where the click sound comes from; maybe the circuit board.
If all else fails, I may just convert it to a 5 speed machine after changing the motor to an AC one. But I really would love the variable speed option to work. Wish me luck.
