We value your privacy.
>I do apologize but I've just spent 20 minutes trying to search the archives for information about soaking Norfolk Island Pine bowls. I know there have been many postings on this subject but I just don't know how to bring them up. I checked "the past year", "all" of these words, then tried 198 variations of NIP, soaking mixture, translucent, homebrew, home brew, etc. etc. I keep getting "0 results for your search"...........I know I'm doing something wrong.
HELP! I have 2 chunks of NIP, can't afford enough Danish Oil, some of you (Russ included, I believe) have posted your own mix to achieve the same results and I can't find them. aaarrrrgggghhhh
>Ruth, try using a homebrew of Boiled Linseed Oil and Turpentine, half and half, and a dash of japan drier. You might want to add some varnish too but this is optional. You can substitute Mineral Spirits for the Turp. All this is from memory and I do not turn NIP so if someone suggests something better.........
>Are you searching the current board(last 2 weeks) or the Turning Archives (menu in the left frame)? I seached the archives for "NIP" in the last 5 years and got 183 hits.
>Ruth I don't have time to look it up because I have a photo assignment in a couple of minutes but do a search for Ron Kent. He soaks his bowls in oil. Don't know if that's what you wanted to do but his sure look fantastic.
>Hi Ruth, maybe check over on WOW. There was a recent discussion about this very subject. I think Kelly Dunn gave a very detailed description of the process. Good luck and show us how it comes out.
I did the search in "Turning" archives for the past 1 year. I know you got 183 hits but there are 180 posts that just have the words Norfolk Island Pine and I just wanted to know the mix to soak the wood in to make it translucent.
>Thank you for taking the time to get this link, John. Ron does a beautiful job with the NIP and (sort of) relates his technique but not what he soaks them in other than saying "oil".
Hope all is well with you and hope you find that "perfect woman"! See if she knows the "perfect man" for me. ; )
2-gallons Mineral Spirits (Odorless because it smells better)
1-gallon Boiled Linseed Oil
1-quart McCloskey's gloss Spar Varnish (red can)
1/2 pint Japan Drier only if the shop temp gets below 55F at night
Turn the wood wet and keep it that way, to final thickness of 3/16" or less, and sand from 60 thru 150 grits. No higher because the finer grit reduces penetration of the finish. Throw it into a bucket of finish, use a brick to hold it down, cover the surface with Saranwrap, and leave it there for a couple weeks. Remove and drip dry for another couple weeks. Then wet sand through whatever grit you want.
For larger pieces that won't fit in the bucket, I keep it saturated and wrapped with Saranwrap so the oil doesn;t dry. Unwrap and reapply the oil daily for the same 2 weeks, and then let it dry for 2-weeks.
It should look like this when you put a light inside.
