suggest best finish for spalt maple
ken chase
>This is my first spalted maple bowl/hollowform. My favorite finish is danish oil followed by beall polish system but I don't know if that is appropriate for this project. Advice appreciated. Thanks
Re: suggest best finish for spalt maple
George Van in WI
>Ken, I have had good luck applying ultra blonde shellac or Deft before applying the oil/varnish. Pre-coating helps control the absorption on the softer areas and thus seems to control the blotchiness associated with spalt and oils.
Carole in VA
>Ken, George is right on. I have been applying a thinned coat of Deft lacquer (wipe it on then wipe it off) letting it cure, sanding with a fine grit then carrying on with oil (I have started using Waterlox rather than Watco. I have also started skipping the oil sometimes on light wood and just build many thin coats of semi-gloss lacquer even though I hate working with the stuff.
Re: followup question
ken chase
>I have often used Deft lacquer,but never wiped it. I will give it a try.
What about just using a few coats of Deft and calling it a day. I didn't realise oil based finishes could be used over lacquer.
Thanks
Wally Dickerman in Arizona
>In my classes we always use semi-gloss Deft. In a class a very quick drying finish is a necessity. I tell the students to brush on a very liberal coat of Deft and immediately, with the lathe turning slowly. polish it dry, using a paper towel. Dries to the touch in about a minute. A second coat can be applied immediately. I tell the students that this is only the beginning of a finish. They must later apply more Deft, or I suggest it be followed with several coats of a Danish oil finish. Several coats of Deft by itself makes a very good, durable finish.
Wally
Earl Eyre
>I may sound like a broken record, but I use Deft on this type of wood, also. Keeps it clear with very little yellowing. I usually just use the spray--a couple coats--then Beall. I love the gloss on spalted maple. But semigloss is great, too.
Earl
ken chase
>Thanks all. I have had a problem polishing a deft finish. In some places the finish broke down or melted. Is it necessary for the finish to dry for a long time before polishing or did I just spin too fast?
George Van in WI
>I cannot help you on this question as I have only used it as a conditioner thus far. Some have mentioned using 3M Finesse-It after it cures.
Earl Eyre
>I haven't had that problem so not sure why it's happening. Maybe too much, too long with the Tripoli? I use the speed suggested by Beall--around 1700. I always have the piece sanded real smooth, sand between coats of Deft, then I only use the Tripoli for a very short time-- a minute maybe and it's buffed. The lacquer is pretty thin unless you have applied many coats, so that's all I can think may be happening.
Earl
Carole in VA
>I have not put either of my lacquered pieces (only done 2) on the buffing wheel because I was afraid it might mess it up. I hand sand each coat of lacquer with micro-mesh up to 12,000. For the final finish I hand buffed with Rennasaince Wax (never could spell that word!) Very time consuming so there won't be many lacquered pieces from me! LOL
