drill press
drill press
drill press
Tony
>If I was to start turning pens, what's the cheapest and best drill press? Is a $150 (or less) Craftsman going to be good enough?
I don't forsee using it for much besides pens and drilling out lamp bases and stuff. So I was looking at a ten inch bench top model.
Thanks.
Re: drill press
Re: drill press
Jack Savona
>Tony, the biggest factor I considered was the DEPTH of my pen drilling. If your choice of drill press doesn't drill through your longest pen blank, I think you may regret your choice. I waited and waited until I found an old Craftsman floor-mounted unit with a deep throw that meets my needs. That feature alone made my $60 investment a great buy.
Re: drill press
Re: drill press
Tony
>well how deep? Do you make pens bigger than say ten inches?
Re: drill press
Drilling depth
Clem Wixted
>Tony,
The up and down motion of the drill bit (spindle stroke) when it is mounted in the chuck is important. Some of the less expensive imports only have a 2 inch stroke. Many pen blanks are more than 2 inches tall so you can't drill through the blank if it is longer than 2 inches.
The other improtant dimension is the throat. The distance from the post to the spindle. That dimension determines how far you can drill a hole from the post. If you want to drill a hole in the middle of a 20" piece and your throat is 7 inches you are out of luck.
There are a few more important dimensions but for pens the key is spindle stroke.
Clem
Re: drill press
Re: drill press
JKJ in East TN
>I bought a Delta bench model drill press and the quill depth was not enough for pens. I drilled part way then finish with a hand drill - not ideal.
I bought a Delta floor model which allowed me to drill through my longest pen blanks. I now reserve the bench drill press for metal work since most of that is with thinner stock.
I don't know whether this is a common difference between bench and floor models from the same manufacturer, but it's something to keep in mind.
Also, if shopping for an inexpensive drill press I would take along a dial indicator and check the runout of the shaft and of the smooth part of a drill bit mounted in the chuck. I've read horror stories about getting machines with unusable tolerances.
Re: drill press
Re: drill press
Tony
>Now that interests me...b/c I assume the Delta bench model is listed as a "10 inch drill press".
Thanks.
Re: drill press
Re: drill press
Bruce Wiseman
>Well I may be wrong but I believe the 10 inches refers to the distance between the post and the chuck. Meaning you could place a 10 inch piece of wood max under the press to drill. The measuremnet you want is quill travel. Most higher end drill press will travel in the range of 3 inches or so.
For many years I made pens using a Craftsman 8 inch that had 2 inches of travel. I would drill as far into the blank as I could then shut it off and place a piece of scrap wood under the blank. Carefully lower the drill back into the hole, start the drill back up and finish the drilling. It wasn't fun but it worked.
Re: drill press
Re: drill press
Tony
>Well I was looking at a Ryobi 12" bench model at Home Depot today--$150 or so--and it claims 3 and 1/4 inches of quill travel.
I dunno, I just hate the idea of dumping $400 into a big machine right now if I don't have to.
Re: drill press
Re: drill press
Eaglesc
>a 10" DP has a distance of 5 inches from the center of the bit to the post.It is stupid but that's what it is.
The ryobi you speak of is what I have andsue it every day.
The quill travel is 3& 1/4 I think.
Anything longer and I drill them on the lathe.
There maybe better DP's out there for less but I Can't complain about the Ryobi for what I use it for.
BTW Many of the kits have a lower section of 2&3/8ths.
Slimlines are around 2&1/16th normally
