ADVERTISE HERE - FREE TRIAL
picture compression
picture compression
picture compression
Patrick Capobianco
>How do I compress picture to fit the posting requirements, I have poly view but not sure how to compress the picture, any help would be apprecitated?
Re: picture compression
Mike Schwing from Md.
>Quick answer - go to the FAQs section (top of menu to left). You'll find an article on the same subject.
Longer answer - use an image editing program to save the picture in a lesser "quality" setting. Images on the turning forum here on WC are limited to 80K each.
Bob Lemon - Sacramento CA
>If you download 'Photofiltre' (free) you will have a relatively easy program to use for sizing pictures. This program allows all kinds of fancy things, but most important are contrast, brightness, and focus. After importing, click the right mouse, 'image size'. You can use a maximum size of 640 x480 pixels for posting on the internet. I use a resolution of 72 pixels per inch. When you are through processing, right click 'save as' and proceed. (I usually save to the desk top.) Name you photo, save as jpeg and press 'OK'. You will now get a window that says 'Jpeg compression' Adjust compression for 40K or less, then click 'OK'. Now you are ready to post on 'optional graphic upload'. Click on 'browse' and import from your file (desktop).
Steven Antonucci
Download MS power tools for XP
steve antonucci
>install and it's a right click to resize an image- small usually fits the 80K limit.
Steve
