Question about filling gaps
Scott Hurley in N. VA
>I just completed this small maple bowl (no finish yet), and it has a fairly large crack/feature/whatever (you can see through it) near the rim. I'm wondering if I should try to fill it, and if so, what should I use? Should I use epoxy, a CA/sawdust slurry, or some other filler? Or should I just leave it alone and consider it a 'feature'? Thanks in advance.
Scott
Re: Question about filling gaps
Paul in Phoenix, AZ
>Coffee grounds and CA will work. Or any dark (contrasting) colored wood shavings. If you use light colored wood, the patch will look like particle board.
Dick Hines
Dick Hines
>Go to your local box store,Lowe's or Home Depot, and pick up some fileings from the guy in the key dept. Pack them in the crack and drip CA glue on the fileings. Don't get near the smoke that will come off the bowl. Bad, Bad stuff.
You will need to sand the bowl again but it will be worth the effort.
GaryG in MD
>Scott,
Two thoughts came to my mind, even before I read Dick's reply.
For light wood like that, I like either turquoise Inlace or brass key filings. Both end up looking nice. The turquoise is a bit passe, but I still like it for occasional use. For darker woods, I like coffee grounds -- they even look good in things like red oak with an oil finish.
A few added comments are in order, however.
You can buy Inlace, or, for a much more economical approach, you can just grind up some blue and green blackboard chalk. The results aren't the same, but I find them equally interesting. The chalk may/will darken to a deep blue/green depending on what finish you use.
I love the look you get from brass filings, and I like how quickly you can patch a hole -- literally seconds for the CA to dry, and you can keep turning. In your current case, however, I would think twice about doing it unless you can put it back on the lathe and turn the brass smooth. In my experience, unless you use a hard sanding block and go very carefully, sandpaper will remove a lot more of the wood around the filler than it will the brass shavings. I generally do a gentle shear scrape over the patched area, and that comes out fine then for normal finish sanding.
P.S. Don't worry if the keys at the machine look "silver" colored; the filings will most likely be a nice pale brass color.
Good luck, and let us know how it 'turns out'.
Gary
>Scott I either highlight the hole or cracks using gold,silver, brass, bronze, etc. or I try to blend it in. I use either sawdust or artists chalk and mix it with epoxy until it matches the color of the knot. I usually go for the darker colors in the knot. Then of course you have to sand and finish over that. I use a curved cabinet scraper to level the epoxy and then sand. You can use a thin chisel if you careful
bob davis
>unless the bowl is intended tobe treenware,isuggest leave ialone,finish it and the feature will enhance it..
leave this feature natural
Ed Karch in No.VA
leave it as is.
DougJ in Crawfordsville, IN
I wouldn't
>This may just be my experience. When I leave cracked pith in the bowls untouched everyone comments on it and shows the defect to friends but they don't buy them. If I fill the crack whether matching or contrasting they sell as well as my other pieces. That may just be my experience but it has happened a couple of times. The cracked pieces just sit there.
>All - thanks for all the responses and options. If I hadn't already finished the bottom, I'd try the brass shavings. However, since it would be very hard to smooth it out now, I think I'll leave it alone and call it a 'feature'.
Scott
