CA glue as pen finish
Paul in Phoenix, AZ
>I tried finishing pens with CA glue yesterday and had a devil of a time doing it. I would sand to 400 grit, add a couple of coats of CA and start sanding with 400 again after it set up. I sanded up to 2000 grit but I seem to sand it all off. Then I started over with the CA and started sanding with 600 to 2000 grit (I don't have any micro-mesh). I did this a couple more times and finally got a finish I liked. It seemed like this took an hour to do for each pen. What am I doing wrong? Is this how it always works when finishing pens with CA? How do you folks who finish pens with CA do it?
Thanks,
Paul
Re: CA glue as pen finish
Scott Greaves in Blackfoot Idaho
>Hi Paul!
Every once in a while I have a CA finish get stubborn with me. I end up sanding it down three or four times before I get it right. But most of the time I can go right to buffing my pen after applying the CA. Here's how I do it:
I almost always use a BLO/CA finish (Boiled Linseed Oil/Cyanoacrylate). I turn the lathe down to a slow speed, and start by putting a light coat of BLO on the pen with a folded paper towel, making sure it gets in the area of the bushings. Then I put a glob (more than a glop, less than a gob) of BLO on the paper towel, and hold it underneath the spinning pen blank, making contact, and drip medium (or thick) CA glue onto the pen blank from above. This mixes the CA with the BLO as it spreads it out, and cures it almost immediately. I can usually do four coats this way in quick succession. If it doesn't appear to be building up, do a couple of more coats. The only reason I don't use thin CA glue is because it takes longer to build up, and it soaks through the paper towel too quick! (Ouch!) If you are sanding to 2000, sand lightly, and then use some polishing compound, such as Novus or HUT Ultra Gloss. Micro Mesh is cheap, and I recommend it.
Note that there are some woods that don't take a CA finish well, and most of these do not benefit from using BLO. Cocobolo is a good example. With Cocobolo, I wipe it down with acetone a couple of times real good, then apply the CA glue with some plastic over my fingers as an applicator. I still do four or five coats, but this I usually end up sanding the heck out of! Still, this is one of the best finishes I have ever used on a pen, and is worth the hassle.
Good Luck!
Scott.
Paul in Phoenix
>Thanks Scott, that's the kind of insight I am looking for. Hope you enjoy your block of olive. ;)
>You are welcome, Paul! And I am relishing the thoughts of working with that Olive! Thanks!
Scott.
