How about a Rikon mini lathe?
Larry Plagens
>Woodcraft has a Rikon mini lathe on sale for $249. Does anyone own one of these? I don't know anything about Rikon lathes. This will be my first lathe so I don't want to get burned if I can help it. Any comments will be appreciated.
Re: How about a Rikon mini lathe?
Jennifer@Indy.USA
>Larry, I've not used one but I've heard that some who have tested it...say it's junk. Apparently the tool rest snapped off and the tail stock won't stay put? Can't speak from my own experience, but that's what's going around the wood vine.
Jennifer
Jim Shaver - Oakville, Ontario
>Hi Jen,
I heard someting like that as well...not a great recommendation then..hard to beat a Jet mini...I love mine!!
Take care,
Jim
Larry Plagens
>I have heard nothing but good reviews on the Jet mini lathe, so that is what I will most likely buy, but I like to consider all the options. Thanks for the information on the Rikon.
>Hi Larry,
It's a common topic here , so I would do a search on mini lathes on the site. But the Jet gets great reviews all the time. In the same market the Delta Midi also is a lathe that works fine, a Good Friend of mine has one and loves it. Then the General International also gets a good set of reviews as well.
Take care,
Jim
Re: How about a Rikon mini lathe? *LINK*
>I guess that's what A. J. was talking about:
Thanks for the kind words
Gregory St. Laurent
>I decides to go with the Rikon after comparing it to a few others including the Jet. What I found was the Rikon was comparable to the fit & finish of the others plus had a little more to offer, the extra capacity and the indexing/locking head to name a few. I've had it for a little over a week and I've put it through its paces and it has performed flawlessly I'm 100% satisfied! I'm adding a bed extension next.
One thing to remember.
Gary Evans Tallassee, TN
>Unlike others, I've heard good things about the Rikon lathe. I have looked at one closely and have good reports from the former President of our club, whose opinion I trust. I also like the extra swing that it offers.
So, having heard good and bad about the product, how do we decide whether the lathe has quality or not?
It seems to me that this lathe is still in the early stages of manufacturing at this point. It wouldn't surprise me to know that several sub-standard units made it onto the market, particularly if they are being pushed into construction to meet marketing goals. It's also not uncommon for a manufacturer to tweak the design in order to answer the initial criticisms and complaints.
I would wager that your chances are better now of getting a "good-un" than they may have been a few months ago. If you can get to a WoodCraft store, you can see the two lathes side-by-side, run them both and make your own decision.
Gary
Re: One thing to remember.
>I agree with Gary. I saw them at Highland Hardware and played with it a while but didn't actually turn on it. It seemed to be at least as good as the jet and maybe better. Highland Hardware doesn't usually carry any junk.
georgetroy
>If you get a China lathe, I would strongly suggest you replace the tool rest. A broken tool rest one time is a risk I do not take. GT
Lan Brady
>I did the same as John. At Woodcraft in Greensboro, I played with one in their shop. I wiggled every bearing and moved each machined part on the lathe. I locked and unlocked every part of the tailstock and tool rest. I slid it forward and locked it in place(4 times) to make sure the points aligned.
I wish they had a loaner program so I could take one home for a week to play!
Lan
Black Bear
>I used one to do a demo at our club meeting at Woodcraft. The 1" threads were really undersized so my chuck only trued up when it was bottomed out on the arbor nut. It had a mismachined handwheel on the other side of the headstock so it added to the vibration the lathe had the whole demo. The tool rest banjo would not stay locked in place no matter how I jumped on the clamp lever.
On the plus side - good power and good swing.
If Rikon can get some early product problems straight, I would buy one but I would wait for awhile to see how Rikon improves the product.
I ended up buying an older "blue" Jet mini from a club member. It will be around long after I am gone.
A Black Bear Turning in Illinois
Gregory St. Laurent
>I have'nt run into any of the problems you've described so far, Maybe They've improved already or maybe there was few duds around?
Ron Ainge
>I turned on one of these lathes at the woodworking show in Denver, Co. for about 6 hours over a two day period. The first problem I had with it was the indexing wheel came loose and it took a couple of hours to get it tightened back in it's place. next the wheel for the tail stock came loose and I had to tighten that back down. I found it hard to change the speed on the lathe because the belt was so small that it did not allow for movement of the motor to release the tension, and lastly the belt began to fray about noon on the second day. I own to old delta lathes and the vs mini jet and I will keep the ones I have thank you.
