Calling Darryl Hansen
MFoster
>I just sanding a bowl with my sioux drill and the rear bearing died. I've had it quite a while, so am not complaining. I have the old model with the switch on the back. I took it apart, and sure enough, it was the rear bearing. How did you remove the old bearing? I'm going to call Boca for a new one (I remembered the recent post and assume you have done this from your message). Thanks in advance.
Mike
Re: Calling Darryl Hansen
Darryl Hansen
>Hi, I put a couple of flat pieces of aluminum stock that I had lying around on either side of the bearing. Rested them across a small bench vise i Hve and ever so gently tapeed the shaft and the bearing slid off. You must be careful not to damage the wirs as you know and be carful when the bearing comes off not to drop the armature on the floor. I think I remember another post that suggested using a grinder in a drill to grind one side of the bearing away and then peeling it off the shaft. Another suggested using a screwdriver and prying it off but I didn't do it that way 'cause I was afraid of damaging the armature. Let my know which way you try and how it works since I have one that is about to go. I forget to blow it out and I think some of the dust got into the bearing it is an old one without the sealed bearing I have in mother one... By the way check the part number on the bearing in case it differs from the one I had that I posted. Darryl
