Playing with Itty Bittys
Carole in VA
>A little cherry goblet. These little things are fun! I don't have any micro tools so I am doing it with my 3/8" detail gouge. Anyone got any suggestions for micro tools? Especially hollowing tools? I am not good at making tools...I don't have a torch and can't bend the hex keys. :(
Re: Playing with Itty Bittys
>Very nice Carol. I have found that you don't have to heat treat miniature tools. They remove so little wood that they don't get dull very fast. I've also found that you don't need a flute on bowl or spindle gouge shapes. Just sharpen them and then polish the top porting between the wings. I made my skew out of a jewelers screwdriver and my gouge out of a nail. My bigger tools (sized to do something as large as your goblet) I used an old drill bit for the skew (the shank, not the fluted part). I simply drilled it into the end of a dowel so just the shank stuck out and then sharpened the shank. To make my larger bowl gouges I took a 1/8" roll pin and drove it into a 1/8" hole drilled into the end of a 1/4" steel bar. I mounted this in a handle. Then grind the top off the roll pin so it looks like a fluted bowl gouge and sharpen like a bowl gouge.
To sharpen these tools I start my grinder and then shut it off. When it gets pretty slow I sharpen them. For the really small ones I use a grinding wheel in the dremel. I just clamp the dremel in a vise so I can sharpen just like I normally do only on a smaller scale.
Ron in Drums PA
>I made some mini tools using cement nails. They are made form harden steel and are cheap enough that you can make a few profiles, ie: skews, square and round scrapers, parting tools etc...
If I remember correctly, John Lucas was the one who gave me this idea
Carole in VA
>Holy cow, John! My eyes are not nearly good enough to turn anything near as small as what you are talking about! LOL You're talking super-micro!
Brian Hahn in SW Wisconsin
>Very nice little goblet.
Making miniature tools from hardened cut nails (cement nails, which now are also available as round nails) has been around for ages. I learned it from my Dad and made miniature carving tools when I was a teenager (umm... 40 years ago). I like the hex wrenches for hollowing because they are very easy. Just cut the short arm real short (1/4" - 1/8") and sharpen. The edge is so close to the center line of the shank that torque isn't an issue. No need for crank-necked tools when you're turning something that size! I use a drill chuck mounted in a handle to hold the tools. That way I don't have to make a separate handle for each tool.
Keith Tompkins
Keith Tompkins
>Roll pins? Hmmmm....great idea, John!
.Bob R
>Looking good Carol. I'm just starting little ones also.
Thanks John and Brian for the hints on mico tools.
Bob R. West Mac Turning
Terry Quiram, Roanoke Illinois
>Carole
I just got a handfull of dental tools on my last visit. Going to try to make a mini captured ring tool.
Terry
>Keith I got it from someone else. They don't actually work that well which is why I started using solid shafts for miniatures instead of fluted shafts. I made 3 of them from roll pins in different sizes and they are OK but since the walls are thin sharpening them is really tricky. That's why I had to try the Dremel method.
Awesome!
Ed Kelle
>Great job Carole! That sure is small. Now all we have to do is figure out if I make an acorn to fit in your goblet, or you make a goblet to fit in my acorn. :)
>The problem with roll pins is that they are mild steel. The steel is designed to be as soft and flexible as possible, so they will conform to whatever hole you are driving them into, and shear off if the going gets tough. That way, you just replace them, instead of whatever it is they are holding together, which is usually made of harder steel. They won't take or hold and edge worth a hoot, and bend if you get a small catch.
Re: Awesome!
Carole in VA
>LOL That would be cute to have a little surprise inside one of your acorns! Don't think I could do it, but John could! I turned a little martini glass tonight then turned a toothpick and a olive to go in it. I lost 3 of the olives when parting them off. They must have gone thru a wormhole and into another dimension. Finally managed to hang onto the 4th one. LOL These things are so much fun. I am going to try and make some hollowing tools.
Re: Awesome!
Jennifer@Indy.USA
>Nice ones Carole! They are SO fun...I just love making the little things.
Jen :)
I love 'em Carole!!
Dave Peebles Lyons, Ohio!
Re: Awesome!
Ed Kelle
>This is another great one. Lets see a picture of that olive. does it have a tiny pimento in it???
Re: Awesome!
Carole in VA
>LOL Yes it does have a pimento, but just colored in with Prismacolor.
