Yet Another Sanding Question
Charlie Anderson
>I just did some boxes but have ended up with sanding scratches on each of them. I'm sure the problem is not properly sanding with the grain with each grit.
Is there any way to easily (more easily?) sand these. It's difficult to sand the 1/2" strip between 2 1/16" beads.
Re: Yet Another Sanding Question
Carole in VA
>To get into tight places, you could try one of the the tiny little 3M thingies on a Dremel. I forget what they are called...I just call them spiders. They are disks with a bunch of little grit impregnated "legs". I mount 6 disks on the mandrel. I don't think you will be able to effectively sand with the grain in the 1/2" space bewteen beads without eroding the beads themselves. Try cutting strips of paper that perfectly fit between the beads and be sure you have removed scratches from the previous grit before moving to the next. Oh, and be sure to wipe the residue between grits.
JKJ in East TN
>For sanding in tight spots I tear cloth-backed sandpaper (Klingspore gold) into narrow strips. (I also use strips for small coves and fillets - twist/roll a strip into a small stiff tube, hold it tight to keep it from unraveling, then rotate it in the spinning cove.)
But if possible, skip the sanding! A sharp scraper used with an extremely light touch might be all you need for a flat between beads. I mean a "whisper" light touch that removes only fine dust. I sometimes use a narrow flat chisel (a skew chisel without the skew angle) or bedan or wide parting tool - hold it flat on the toolrest at or slightly below centerline. Works great for gavels and boxes. All it usually needs afterwards is a bit of 400 paper.
Thanks guys
Charlie Anderson
>I recently was using as a signature on another board, a cartoon with a caption that went something like this. "I thought that in retirement I was becoming much more patient and layed back; but it turns out I just don't give a *&%#!"
Unfortunately, that doesn't work in woodturning.
Oras Art Liestman says, "Good enough is not good enough"
So I'll try JKJ scraper idea and if I sand, show a lot more patience.
