Too sharp - ouch
Too sharp - ouch
Too sharp - ouch
Mike Schwing from Md.
>Maybe. I just accidentally bumped my hand into my 3/4" Ellsworth and sliced my pinky right to the bone. Bottle of CA helped immensely this time. Rather than gluing myself to the lathe, it closed that wound up right quick.
So much for swimming with Miss Kidman later on today.
Re: Too sharp - ouch
Jim Shaver Oakville, Ontario
>Hi Mike,
Me thinks you are stuck on something (one)...leave the CA at home...
take care,
Jim
>Mike I have done that only not that deep. When I was demoing in Atlanta a few weeks ago this guy came up after my demo and picked up my gouge and ran his finger across the tip. He looked sort of funny, put his hand in his pocket and promptly left. I suspect he cut his finger.
>Always the stupid things. I had just sharpened it and honed it, too, for some finishing cuts on an interior surface. Dummy me had stuck it in between the legs for just a moment to make an adjustment to the lamp, and stupidly pointed the sharp end up. Being literally razor sharp, it took no effort for it to slice right through my little finger as I simply moved my hand across a plane where there is normally nothing sharp in the way.
The funny thing is that no matter how many times I use CA to close a wound I always figure it is going to hurt like he*l, but it is always totally painless. Except for that one time I sprayed accelerator on.
Carole in VA
>Ouch! Good thing you didn't lose your grip on it with it between your legs...if you had and it happened to fall the wrong way, your voice might be a little higher! LOL I have cut myself on mine but not nearly THAT deep.
Question for Mike
>I keep hearing about closing a cut with CA. I have plenty of CA and an occasional cut. Exactly what do you do? Press he edges together? Coat the surface? Please explain. It seems to me it would sort of seal the surface and make your body heal under it. Can't quite imagine, but I know it works.
I once reached inside a hollow form with my Ellsworth Gouge and smoothed the inside, managing to pack the flute full. I pulled it through my left hand to clean the debris. Double ouch. Don't do that.
Re: Question for Mike
>I don't know how the surgeons do it, but I open the wound, drizzle in CA, and press closed until it cures. Really does work, right quick.
Don't spray accelerator unless you're prepared to scream!
Michael Sinclair
>My wife says to hold the wound together and pour the ca over the top of the wound, it doesn't hurt so much this way. She is a paramedic and its how they were show to do it in A&E.
mike.
Craig Daymon
>I believe this is fact, CA glue was developed for the military specifically for closing up wounds in the field. (Field stitches, so I think proper technique is to push the wound together and apply a little CA.)
-Craig
Thanks everyone.
>After posting the question I nicked a finger tip and was bleeding on a turning. I, to quote Shakespeare and make a bad pun all at once, screwed up my courage to the sticking point and coated it with thin CA. Didn't hurt and it worked.
There is something about this that defies logic either way. If you apply CA IN the wound, doesn't your body have to absorb it in order to heal? Otherwise, where does the CA go? OTOH, If you put the CA OVER the wound, how does it hold it shut? I suppose some soaks in anyway, but then we are back to the first question.
I have a friend who keeps it in his shop just for cuts. It never occurred to him to waste it by gluing something. I'll have to ask him, but I think he uses the pinch and apply method.
Dick Hines
Dick Hines
>If CA burns any thing like New Skin I had rather bleed. Bleeding is more manly anyway.
My wife used New Skin on me once. Set me on fire. Of course I am a wemp when it comes to pain.
tek-Brunswick, Ohio
>I've used both! They are not at all alike. I first tried the New Skin on an abrasion, with lots of surface area. Yikes! The cure was worse than the injury! The CA Glue doesn't burn. They use a skin glue called derma bond at the emergency room. The Derma Bond the Emergency room used on me was more like the thick flexible CA glue, but it didn't smell like any CA I've used. (Mike bumped a freshly sharpened gouge. I bumped a freshly sharpened Ax! Seeing your tendon through your wound is not a good thing!) I prefer the Derma Bond instead of stitches when possible. I didn't need any Lanocaine with the derma bond. If I would have chosen stitches they would have numbed my hand and I couldn't go back to work immediately.
>Dick Back when I was rock climbing we would just close the wound with CA and keep on climbing. that stuff is great for that.
Fog Tanner
>You are most correct, it goes back to Nam. They used it for stopping bleeding so they could work on the wound(s). I have been using it for around thirty years now to "fix" accidents. More than once I have sliced my finger with an Xacto knife and glued it up and gone on with my model airplanes. I have one piece of tissue that was inadvertantly removed from one of my fingers twenty years ago, the night before a race. A little cleaning and placed it back in its original location and added the hotstuff. I went reacing the next day and didn't even know that I had lacerated finger, except for the badaid that had gotten glued to my finger. It was healed within a week, about the same length of time it took for the bandaid to wear off.
You clean the cut first, so as not to seal the dirt in, hold the cut closed and add the Hot Stuff. It will wick in the cut and glue the skin together. On really bad cuts where you have a lot of flexing, you may have to redo in a few days. Body oils will loosen the glue, one reason it doesn't work well on glasses where they come in contact with your face. But, also a reason they use it internally.
