Beall system
Patrick Capobianco
>Is the Beall system worth having? I just finished a bowl and was thinking about picking up the Beall system at a Woodcraft store but don't want to spend the money if it's not going to make my prodjects look nicer.
Beall system
Patrick Capobianco
Re: Beall system
Ken George
>Not an expert by any stretch of the imagination but I prefer the Beall system and the resulting smooth matte finish. My family prefers the glossy look so I do some poly finishes, but not many.
I usually use 2 or 3 clear Watco coats, let dry for a week or two then finish with the Beall system. If I want more gloss I use a coat or two of Briwax, hand buffed. I am looking for something to use for buffing the Briwax but haven't found anything yet. Saw something recently while searching for buffing mops at an Australian site but they were shut down until Dec 15. Don't remember the name of it but will look again after the 15th.
Re: Beall system
Carole in VA
>The first two grits (tripoli and white diamond) take out microscopic scratches and the carnuba is a durable, hard wax. Buffing makes a big difference on a well prepared piece. BUT if the prep work (tool work and sanding) is sloppy the buffing can make it stick out like a sore thumb. This is a good thing, BTW, because you learn to get better at what you are doing! ;) Be careful with the white diamond on dark wood...it will visibly collect in any open pores. Basically, I think the answer to your question is an emphatic "yes" the system (or a clone) is well worth the money. I use the Beal bowl buffs (not just on bowls) because I haven't gotten around to getting the wheels.
Re: Beall system
>Patrick there's little doubt that it will make the bowl look and feel nicer unless you spend a lot of time hand sanding. The problem is I don't think this is the best finish for a bowl. If you use the bowl for anything other than display or putting nuts and hard candy in, the finish that is left by the Beal will wear off. At least the Carnauba wax will. The other 2 steps are simply smoothing out whatever finish you use. I use Lacquer the Beal system for all my showy bowls that probably won't have anything in them that will tear them up. On my other bowls that I think people might use I use Walnut oil and then buff with the Beal but I tell them that with actual use they will get more of a satin sheen. I try not to use the work "dull" as this sounds negative.
Re: Bealle system
>I'm not an expert either, but I bought the Beale system and have been very satisfied. I'm not sure how Ken is getting a matte finish. I sand everything to at least 400 and often 600 and then start with the buffing. (Feel myself being drawn to the finer side and may have to sand even further). But there is clearly a difference in the objects even if you don't put on the carnuba. Carole is right, The white diamond will accumulate in dark wood and also the tripoli will change the color of "white" woods. So you may choose to use only white diamond on some really light woods and tripoli on dark woods. The last bowl I did was cherry and I buffed it with both and then applied the lacquer. I'll let the lacquer cure for several weeks and then buff it again. Some finishes may take 30 days to fully cure.
So the answer is, Yes, it makes a difference and people notice it. You will have to learn to make it work for you.
Re: Bealle system
Carole in VA
>You buffed it before applying lacquer? Does the carrier in the compounds (a wax) affect the lacquer?
Re: Beall system
Brian Hahn in SW Wisconsin
>I like the Beall system. I've even made sets of 6" and 4" buffing wheels for smaller pieces. For the 6" buffs I had to stack several to get a nice width and remove most of the stitching. By the time I was done, it would have been cheaper to buy the smaller Beall buffing wheels as well!
Re: Bealle system
>Carole, I posted the same question several weeks ago and Russ answered it for me. (Thank you again, Russ) You might want to search back for that answer, he's better at this than I am. Anyway, he explained that the binder in the tripoli is animal fat, tallow. Smell familiar now? Basically, the white diamond is in a mix of paraffin and carnuba and removes most of the residue of the tallow. And that it is "safe" to apply the finish over the white diamond. The cherry bowl I did with Deft from a spray can is looking good and the finish is bonded to the bowl as securely as ever, as far as I can tell.
Some people say the first half of the work is making the piece and the second half is finishing it. I always thought that making it was most of the work and then you just slapped a little finish on it. Wrong! Actually, half the work is getting the wood. Another half is getting the shop setup right and having the right tools. Then there is the half that involves prepping the blanks and the drying and bagging and tagging and so on. The fun half is turning it. Wait! how long have I been out of half's? I really do need to get better at finishing and work on it more.
Re: Bealle system
Carole in VA
>Sheesh, I am getting senile! I remember that thread. In fact I am not so sure I didn't ask the question! LOL
Re: Wax and lacquer
RussFairfield
>Wax and lacquer will mix, just as wax will mix with either oils or shellac.
The wax becomes a part of the finish and acts as a plasticiser. The result is that the finish will be softer and more pliable than it would have been without the wax. How soft and how pliable depends on how much wax.
If you are using a paste wax under the lacquer, just make sure that all of the volatiles and thinners in the wax have evaporated. Some of these volatiles may not be compatible with the lacquer, and can cause problems.
If using a paste wax over a lacquer film, make sure there is nothing in the wax that will damage the lacquer film. Briwax has a warning on their label. Others do not.
Re: Beall system
Earl Eyre
>I love the Beall system and find that it enhances whatever finish I use. If I want a glossy finish I apply a couple coats of Deft, then go through all three steps with the Beall and get a very shiny finish that people just seem to love rubbing their hands over. If I want a matte finish, I use a tung oil mix. Shellac comes in between matte and glossy.
I haven't tried using the Tripoli before finishing. I just sand and sand until I can't get the piece any smoother, then apply finish, then buff. Comes out beautiful.
Earl
