We value your privacy.
>I know this has been addressed slightly in the past regarding engraving your signature and date on the bottom of your turnings, but what about signing in ink? I have heard mention of gel pens before and was wondering what kind, size, etc... Also, do I sign and date before I put the finish on or after? What about Sharpies? Sorry for all the questions but for my exchange turning I'd like to do it right.
>When I first began turning, I used a disposable pen (Bic or papermate). Fortunately I wised up within a couple years, even before the ink began to fade, and that didn't matter much since I didn't sell much back then anyway. I used a permanent Sharpie fine tip for a while, which was a lot better then switched to a Dremel engraver, the buzzy thing with a vibrating tip. I use the finest setting, or close to it, with a light touch and go slow. I've used a Pilot fine-tip gold marker to fill in the sig, after a coat or two of finish is applied, so it doesn't soak into the wood on the surface around the engraving and that extra spillover can be sanded off. This looks really nice on dark woods like Walnut.
I honestly don't know how long the gold marker will last before fading, but when it does at least the impression will still be there.
>On lighter woods I use a pencil. The carbon in the lead is naturally black and won't fade. It's already a million years old. I am thinking of one of the buzzy things for darker woods. Not much luck with inks. They fade and bleed into the finish.
>If you want to use a pen, try the archival ink pens that scrap-bookers use. Pigma Micro is one brand that works well and the dried ink doesn't seem to be affected by the solvents in whatever finish you choose. These pens can also be found in most art supply stores and I think I've even seen them in Wal-Mart.
Having said that, I sign all my pieces with a vibrating engraver. Permanent (try fixing a mistake!) and works on virtually everthing (except diamond and maybe carbide).
>I used to use various pens, then I tried the engraver and used the gold wax stick to fill it in on dark woods like B. walnut and the like. Now I use a burner for everything I might still use the engraver for ebony or blackwood... HTH
>I use a Pilot Photographic Marker available from Porter's Camera Store. It's designed for writing on photographs. It has a fine black tip, dries instantly on any finish, doesn't smear and is permanent. It's great for writing on many surfaces when the Sharpies won't work.
>I use a burner. I find I can control that easier than an engraver. (Of course the only engraving I have tried was with my Dremel tool.) I burn my name, the species and the date BEFORE applying any kind of finish. If you do it after applying an oil or other finish, it does not burn as sharply because it has to melt thru a finish first (or something like that). I also make sure the base is sanded very smooth to a high grit before burning.
>I sign at the end of sanding (before finishing) and go over the writing with the final grade of sandpaper to smooth off those little ridges of broken fibers. I use setting 3 on my Dremel, it seems to work better in hard woods like oak and hickory. I just have to use a very light touch on the soft woods like butternut.
