What is it with box elder?
Greg B�tit, Crown Point NY
>I've got a few on my property that I need to whack. They're not really great firewood, and I'm not going to turn chair legs from them because they're too gnarley. They've got the interesting red heartwood, but I understand it turns brown with light exposure. I've tried to make chair legs out of it, and it fuzzes easier than anything else I've tried. So why do you turning folks like this stuff?
Greg
Re: What is it with box elder?
>Greg I don't have trouble with the fuzz. Maybe my tools or technique is better but it's never been much a problem. As far as the color goes if you use a UV finish like Russ described earlier the color lasts a long time if stored indoors. I have tried using Binh Pho's technique of airbrushing over the color. The air brush dyes last a lot longer and you are mimicing the same color.
I just like to turn it because it's beautiful.
Jim Shaver Oakville, Ontario
>Hi,
It's also called Manitoba Maple. It offfers not only wonderful oppertunies with colour, but often has great burls!!
Take care,
Jim
Brian Hahn in SW Wisconsin
>It's cheap (usually free for the taking) and relatively easy to turn which means that it is a good practice wood if nothing else. As John and Jim mentioned, it can also have very nice figure and/or color.
Anthomy Y
>It sells!!
>Very nice. I've seen figure like that in the woodpile, I guess I'm going to have to take a hunk into the shop sometime and see what I can do with it.
Greg
>That is gorgeous!
Greg
RussFairfield
>If there is any color change, it is that the red will fade to a lighter pink. I have never seen it turn brown.
This one had a general red blush rather than any defined lines. This blush often comes out as it is turned and sanded. It still has pretty good color after 15 years.
Mike Cyros
>I've just recently finished several bowls from box elder. The wood was free for the taking at our local compost dump, and it has nice red colors (a fungus?). The wood is relatively soft, so turning is quite easy (it is great for practice). My bowls were rough turned in June, and just finish turned for Christmas presents. I'm just oiling them now (Bush Oil), and then will use my Beall to finish.
BUT... No one mentioned how bad it smells when green!! Has anyone else noticed that?? it has to be one of the worst smelling green wood I've tried on my lathe.
Don Henthorn
>I have turned one piece which that nice lady from Virginia (whose name isn't Virginia) sent me. It was fairly green. Luckily my life's experoences have completely destroyed my sense of smell so I can't certify that green box elder has a bad smell, but it is sure fun to turn aand looks good too.
