Turning tool sharpening
Mike Mullen
>I posted this question in the general area of the message board and again here. I need some advice on which way to go for sharpening lathe tools. I have been looking at the Delta Industrial model 23-710 Sharpening Center. Is this a good machine? Or should I go for a jig on my grinder? Thanks, Mike
Re: Turning tool sharpening
Garrett in Victoria
>Tha sounds like the dry wheel, wet wheel machine. If so, run away. Almost useless. (DAMHIKT.)
Instead make or buy a Wolverine style jig for your grinder. Made by OneWay specifically for turning tools and available from lots of retailers.
Cheers, Garrett
Mike Mullen
>Hi Garrett...thank you for the advice. You are not the first one to tell me that and I am convinced now to stay away from the Delta machine. I'm going to build my own like you said. I have downloaded a couple sets of plans and am going to proceed from there.
Thanks again, Mike
Keith Tompkins
Keith Tompkins
>HI Mike...Garrett is correct...besides, a jig eliminates the frustration of badly sharpened tools. A consistantly sharpened edge is a great asset, esp. to a new turner.
Woodenhead
>I too am a new turner. Actually not even a turner yet, because the lathe will be a christmas gift. I am trying to figure out which grinder is acceptable for a beginner. I have searched this site and found that what works for some does not work for all. Some had problems with Delta,some with Woodcraft, etc. I have a bench grinder, but it is 3400 rpm. From what I have read on this forum, I believe that I probably need something slower. Also I understand that a jig is a must, but there a different types here also. The more I read the more confused I become.
Keith Tompkins
Keith Tompkins
>Run what ya' brung...the high speed grinder is fine...save the money for a grinding jig. Just put on a white or pink wheel, and go easy on the downward pressure on the tool. You should have no problem..all I use is a high speed grinder.
Don Henthorn
>I agree. Use the grinder you have but be sure to get a wheel dresser and keep you wheels freshly dressed. If your wheel is clean and level, light pressure will do as good as you can get.
Russell L. Babbitt Jr.
>Keep your grinder....just remember it goes fast so you go slow......
>I think you would find the Wolverine jig and a slow speed grinder is the most popular..
Woodenhead
>Thanks for the responses. Sounds like fine advice to me. I'll put the jig and wheel dresser on Santa's list. Hopefully by this time next year I'll have some experience and be able to give someone else some advice.
Mike Cyros
>Good advice from the others not to get the Delta shapening center - it is really junk - mine is relegated to sharpening my lawnmower blade (which I just did today actually on it), and nothing else. Woodcraft sells a decent quality Taiwanese 1750 rpm slow speed grinder that actually comes with some have decent wheels. Invest in the Wolverine system like others have recommended (I strongly recommend the diamond point dressing jig - it makes a huge difference on the cutting ability of the wheels!). Also, get the vari-grind and skew jigs as part of your kit. I've been very happy with the wolverine jig and my woodcraft grinder.
