Faceplate deal for 3520 owners (or 1-1/4"x8TPI)
Craig Daymon
>In looking for extra faceplates for my new 3520, I checked out the machined steel 4" FP's at Woodcraft. Seem like a good deal at about $30 each. While there, I took a look at their closeouts.
On the first page of the closeouts was a product described as,
"Index Faceplate, 1-1/4"-8 Prebored Thread"
for $25.99. Sounded interesting and the threading was right for my Powermatic, but not very clear what it was. Turns out to be a 150mm (just under 6 inches) Aluminum faceplate, acccording to Tech Support. Normal price was $49. I bought 3.
This is a closeout item, so I thought I'd let everyone know.
-Craig
P.S. These were originally designed for the Nova (DVR?) lathe, I hope that doesn't mean the threads are LH instead of RH.
Re: Faceplate deal for 3520 owners (or 1-1/4"x8TPI)
>No they are right hand threads just like the powermatic. I had one with my Nova. I never used it. The only problem might be the length of the treaded portion. You may have to use spacers between the faceplate and spindle but I can't say for sure because I don't have that faceplate anymore.
MP Wall
>If your PM lathe is fairly new you can request a spacer from PM and they will ship it out to you. MP Wall
George Van in WI
>I was just told they are out of stock. SHUCKS!!
Craig Daymon
>I'm not quite certain I understand what is needed here. Is it that there is too much thread on the spindle for this faceplate or too little? What will the spacer do for me?
Thanks,
Craig
P.S. The lathe is new, but is a 3520A, so the older model.
George Van in WI
>Craig, there may be too much thread on the spindle for the faceplate to bottom out on the spindle. Washers will help but some worry about run out if they are used.
Craig Daymon
>Thanks George, I'll contact PM and see if they'll send me out a spacer.
-Craig
