This one should be in the FAQ
Mike Schwing from Md.
>Here are all of the responses to a similar question on another turning forum.....and as you will see at the bottom, a suitable solution was found.
Rick Prevett - Sep 19, 2005 Viewers | Reply to this item
If the dark marks are where the CA has wicked past the cracks into the surrounding wood, I wish you luck in finding a suitable finish. I've not been sucessful in finding such a beast. The trick I found is to coat the area surrounding the crack with a sealer _before_ you apply the CA. This will stop the glue from spreading to the surrounding wood. I'll be interested to see what others say.
Jamie Donaldson - Sep 19, 2005 Viewers | Reply to this item
Rick is exactly right-I seal with lacquer based sanding sealer before using any CA to reduce the wicking, and any finish will show those shiny spots or lines unless they are hidden before finishing.
John Lucas - Sep 19, 2005 Viewers | Reply to this item
Allan Rick gives you good advice on sealing the wood before CA. Sometimes you can hide the CA marks by applying more thin CA. Put it on the vessel and rub it around with WAX paper. Sometimes it works and sometimes the stain just shows through.
Mike Schwing - Sep 19, 2005 Edit | Delete | Viewers | Reply to this item
Allan, I ran into this problem just this evening, but with a carved piece rather than a turning. I needed to stiffen up a too thin section of spalted maple (not the greatest carving choice), so I drizzled CA over it. That worked great, but I immediately recognized that I was going to have finish issues, because it dripped over more of the surface than I had hoped (of course) and even though I knew better, I didn't prep the other surfaces beforehand with wax or something that would prevent the CA from settling in.
So what was my solution? I coated the whole thing with the same CA and I now have a very even looking surface that I can move from there on to finishing. The only thing that really suffered were my eyes and nasal passages.
Steve Worcester - Sep 19, 2005 Viewers | Reply to this item
I did a repair on a piece a while back, sanded up to 600 and then shot about 6 coats of pre-cat lacquer over it. Every where there was CA, you could see that outline of the glue. Even when wet sanded and buffed, you could still see a slight "plateau" where the CA was. I am absoultely positive that I sprayed enough coats of finish to exceed the height of the glue. But you could still see it. At least I could. Odd.
Henry Ensley - Sep 19, 2005 Viewers | Reply to this item
Allan- I've had the same problem twice now. The first time, I used Mike's solution; I basicly used CA as a pre-finish. After rubbing CA all over, I sanded again and applied wipe on poly. To my amazement, it worked out very well with no blotchy parts. CA's fumes are very dangerous, and I found that CA reacted with vinyl gloves/paper towel....it started burning and melting the vinyl glove!!!
The second time it has happened to me is fairly recent....on a piece I havn't finished yet. I guess I'm trying to sand out the CA marks (what a chore!!!). I find Rick's advice to be helpful, for the future. I think many people here can relate to this topic.
Henry
Allan Cusworth - Sep 19, 2005 Viewers | Reply to this item
Thanks for the tips. I shall do things differently next time. I will coat the vessel with CA and see what happens. Someone mentioned that some finsishes didn't show through but I can't remember who said it. Perhaps they weren't as exacting as we are.
Anyhow, many thanks for the input. I'll post a picture of the results.
Allan
John H. Williams - Sep 20, 2005 Viewers | Reply to this item
I don't know the generic name of the plastic material used in shopping bags, but pads of it allow you apply CA glue rather evenly. I use it to finish small pieces only however.
OB O'Brien - Sep 20, 2005 Viewers | Reply to this item
Allan; The others have given you great advice. I find a quick thin spray of deft lacquer over the area to be CA glued helps prevent bleed over and ruining the finish.
Hope this technique helps.
Malcolm Tibbetts - Sep 20, 2005 Viewers | Reply to this item
Just one more word of caution - be very, very careful with the fumes from CA glue. Permanent lung damage can result from too much exposure. Personally, I hate the stuff. Well-known turner, Bill Hunter spent a long time trying to recover from the effects of CA.
Jack Nissen - Sep 20, 2005 Viewers | Reply to this item
Hi Allan
Mike's suggestion is a good one. I use the "put it all over the piece" technique he suggests often. (If I bought stock in the company that makes the ca I use, I would be rich.) Also, when a piece has prexisting cracks, it is usually prety rugged, burlish etc. Likely to have a lot of color and texture variation anyway, so an extra spot or two of difference where the ca has spread is not fatal.
Malcolm:
Thanks--I had always thought, and I think I even read it somewhere, that while irritating as hell to eyes, nose, throat, and lungs, ca fumes were not harmful. I will be much more careful now.
Jack
Allan Cusworth - Sep 20, 2005 Viewers | Reply to this item
Thanks for the added info and especially the safety concern for the CA fumes. I'll be very careful.
Allan
Richard Allen - Sep 20, 2005 Viewers | Reply to this item
There is one finish which works great over CA. PAINT! After all isn't teh form the primary artictic valvue of the piece. This is a chance to geso the form and do a little line carving...
Good luck
William Flewelling - Sep 24, 2005 Viewers | Reply to this item
Bill Flewelling-Sept 24,2005
Allen
I use lacguer sanding sealer thined at least fifty percent with lacquer thinner(do not use water base) and I have no c.a problems. Sealer before C.A.
Good luck.
Hought Wahl - Sep 25, 2005 Viewers | Reply to this item
Allan - when you go to coat the entire piece with ca - a good technigue is to use a bit of 100% polyester batting (from craft store) held by a pair of forcepts - drizzle the ca on the poly while slowly turning the piece and keeping a 'wet edge' as you coat the piece. This will prevent multiple coat buildups and reduce the sanding. 2 coats, sanded to about 400 between and after, and then buffed yields a great finish. Good Luck!
Ed Karch - Sep 25, 2005 Viewers | Reply to this item
I did the same thing two days ago While repairing a break in a pierced pot I dribbled CA on the pot and me. The break was sanded and ended under paint so it didn't show but the dribbles were on the part not painted. One got some pyrography to cover it which left two drops. I smeared on lacquer sanding sealer and then brushed over with lacquer thinner and wiped it down with a paper towel and after about 5 minutes smeared on another coat of sanding sealer and wiped it off. Using the sanding sealer as a wipe on lacquer covered the CA so that I now can't find where the drips were. The finish was left as satin. If I had gone on to gloss the dribbles would probably show up.
Allan Cusworth - Sep 29, 2005 Viewers | Reply to this item
Thanks for the further comments. I applied CA over the entire surface using waxed paper as an applicator and it worked well. I will try the other methods if I ever need to. Meanwhile, I think the best way is to avoid the cracks in the first place.
Great feedback, many thanks to all.
Allan
