bowl finish
bowl finish
bowl finish
Patrick Capobianco
>I just applied mineral oil to my maple bowl, can I also apply a wax to give it alittle more sheen, and how long do I have to wait to apply the wax?
Re: bowl finish
Re: bowl finish
Don O.
>You can definitely apply wax over mineral oil. Many people use a beeswax/mineral oil combination to assure food safety. You should be able to put the wax on any time after the oil has soaked in a little. Some people put the 2 on at the same time and work them into the wood. Remember that mineral oil will never dry/harden/cure, but is easily replenished as needed.
Show us a picture of the finished bowl if you get a chance.
Re: bowl finish
Re: bowl finish
Patrick Capobianco
>If I could figure it out I will send a picture.
Re: bowl finish
Re: bowl finish
adrien
>I think you've confused mineral oil with the ones that will polymerize and set up. Mineral oil stays liquid while tung oil, linseed oil, etc hardens.
Re: bowl finish
Re: bowl finish
Don O.
>I just read the post again. I stated that mineral oil will NEVER dry/harden/cure, but can be replenished, like for a cutting board. You are correct that it stays liquid. In fact in some places it is labeled "Liquid Parafin".
