Nested bowls... the hard way
Ed Kelle
>A friend ordered a set of 3 nested textured bowls, which was a real challenge for me. Especially because I do not have a bowl coring system. I had to do it with 3 different pieces, and knowing how much cherry likes to warp, I had to keep this in mind when I roughed them out. So I gave them about 1" thickness just to be on the safe side, much more than is recommended with the DNA method, but I didn't want to take any chances and end up without enough thickness to texture the rims consistently. And I was down to my last few larger pieces of cherry too. Pressure was on. First large piece.. yup I found a nice knothole and it flew out, so that was not acceptable. (But it did lead to my textured knothole bowl). Tried again and was able to get a them all roughed out no problem. Soaked them for a day and wrapped them and let dry. After a few days I noticed some checking starting to appear on the smaller ones. I REALLY did not want to look at the big one, but luckily that was just fine.
A few weeks later and I started the final turning. The big one went well, got past the few minor checks to good wood with the 1/2" thickness I needed for the rims. Then onto the medium one where it got interesting. Luckily I guesstimated it right when I sized the roughout, so when it was trued up it was a decent size in comparison, and a nice height when sitting inside the larger one. The smaller one was a bugger, has a bunch of checking that I sealed with CA. I went just a hair too low when I made the rim, but otherwise it fits pretty well. This was the first time I used a ruler in my turnings. It is definitely not my style to get math mixed in with turning.
I am happy with the results, but it sure isn't a challenge I need any more in the future. Maybe Santa will bring me a coring system ;)
Bowls head out to their new owner tomorrow. Cash on the barrel, no woodden nickels accepted.
Re: Nested bowls... the hard way
un nested
Ed Kelle
Re: un nested
Craig Daymon
>Very nice looking set Ed.
-Craig
Jennifer@Indy.USA
>Ed these look fantastic! I'm with you...I hate to mix math with turning....actually I hate to mix math with anything! Ha!
The bowls look like they fit perfectly and the textured rims really add a nice feature. Nice finish too! Congrats on the recent sales....I need some of your good fortune this weekend!
Jen
Re: un nested
Ed Kelle
>Thanks Craig
Ed Kelle
>Thanks Jen. that sure was a learning adventure.
I have had some recent "minor succeses" but trust me, it sure didn't add up to any fortune! haha
Hey good luck this weekend. Wear the earrings and flash that great smile, I am sure your sales will be thru the roof
BTW- thanks for the pix of my works, I downloaded it for my album
Re: un nested
George Van in WI
>I like everything about these Ed, shape, form, finish, and the texturing is the �eye candy�. The sizing is very well done. Great job!
What finish you use on these?
Jennifer@Indy.USA
>Oh, Ed....those pictures of the acorns and the little bowl were not very good, I didn't think. They were quickly taken in front of a piece of art paper on the kitchen counter with flourescent light!
Ug....I'll re-do them one day with the proper set up and send them to you.
Jen
Pat Mulligan
>Nice job,Ed.Definitely a different experience when you have to start measuring things.
Terry Quiram, Roanoke Illinois
>Ed
The bowl set turned out very well. Nice color, looks like you gave them a couple coats of sun. How did you texture the rim? It is a nice touch.
Terry
Re: un nested
RussFairfield
>Very nice set of nested bowls, and the photos are good. You did well with the finish in the Cherry. Are those coffee grounds that I see on the rim??
You did a good job of getting the 3 bowls equally spaced in diameter and shape. The coring system won't make this any easier until you have had a lot of practice with it.
Re: un nested
Ed Kelle
>Thanks, the finish is Liberon Oil, just the regular wipe on, not the turning version. About 7 coats or so and it builds up a shine.
Re: un nested
Ed Kelle
>Thanks Russ, the rim is textured with my Dremel and stained.
Yes the coring system might not help that much, but at least I won't be wasting nearly as much wood. I'm keeping it in mind for the future, first I need a better lathe and that is at least a year away.
Ed Kelle
>Don't worry about it Jen, I can color correct them here. I'll send you a copy when they are done
Ed Kelle
>Thanks Pat, I still think luck played a good role too
Ed Kelle
>Thank Terry, rim is textured with a dremel and stained. No sun involved, so far their life has been spent under nasty flourescnent lights. yuck
Whoa Ed! These are stunning!!
Molly Winton
Re: un nested
Rick in Colgate, Wi
>Ed,
Beautiful work, very well done!
