THE WOODRAT IS BACK!
acrylic paint, finish, too?
Ed Moore
>I have put several coats of acrylic paint on a turned box. Should I leave it that way, or should I add a clear coat of something to protect the paint? If so, should it be acrylic spray, or should it be some other finish?
Clueless in SW VA
AKA Ed Moore
Re: acrylic paint, finish, too?
robert davis
>suggest u spray coat of satin lacquer,deft is good bob davis kansas
Maybe not lac
John Trant (Baltimore/DC corridor)
>I heard somewhere that lac should NOT be applied over acrylics. No experience, just hearsay.
John
Brian Hahn in SW Wisconsin
>Acrylic paints are pretty tough, but I'd put a protective coat on top.
The various Krylon art finishes (Fixatif, Matte Acrylic Finish, Gloss Clear, etc.) will give a durable finish. I once watched an artist apply a coat of Krylon to an acrylic painting that I had just purchased, so there doesn't seem to be a compatability problem.
On the other hand, the various acrylic paint mediums can be used and they will provide a tougher surface. For example, the Liquitex gloss medium is also used as a permanent protective gloss varnish for paintings. I haven't tried it but I imagine the air-brush medium would also be an excellent top coat. You could spray/air-brush any of them if you didn't want brush marks.
One nice thing about acrylic paints is that most of the pigments are "archival" so you don't have to worry about fading.
