bowl finish
bowl finish
bowl finish
Patrick Capobianco
>What would be a nice finish to apply on a maple bowl,and also food safe?
Re: bowl finish
Re: bowl finish
>Most cured finishes are "food safe". Whether or not they are "water safe" is another kettle of fish. Walnut oil is good if you have the time (and the people aren't allergic to walnuts).
Re: bowl finish
Re: bowl finish
Dennis Thomas
>Patrick,
I used General Finishes Salad Bowl Finish (WoodCraft) on a recent Salad bowl. Finished with the Beall system.
Dennis
Re: bowl finish
Re: bowl finish *LINK*
RussFairfield
>There are only three (3) criteria for the inside of a salad bowl. It doesn't flake off, it must be renewable as it wears away with use, and it cannot have a smell like paint or rancid oil.
That means there cannot be a brittle surface film, and it must be something that can be renewed by the user who knows nothing about finishing and with available kitchen products. The last one means that it has sat long enough that the solvents in the finish have evaporated, or the finish didn't turn rancid with age.
Many prefer Mineral Oil or beeswax because it does all of them quite well. Some woodturners like to mix them together. Others like to add a little Citrus Oil for the aroma. Beewax looks good on Maple and it smells nice and clean by itself. Others prefer a drying oil, and that is fine so long as there aren't enough coats to form a surface film. For a non-drying oil finish, I like Sunflower Oil (not Safflower) because it stays looking nice longer and smells better than Mineral Oil, it doesn't turn rancid like other salad oils, nobody has been found with an allergy to it, and I can buy it at the grocery store.
You can use anything you want, or as many coats as you want, on the outside.
As for food safety, read the article at the link and make up your own mind.
Food Safe?? What it means.
Re: bowl finish
Re: bowl finish
Jim Pugh, Ohio
>Patrick, picking up a little on what Russ said, I use a homemade mix of 1 part beeswax to 4 parts mineral oil. It looks like clear, soft shoe polish and smells like beeswax. Just wipe it on and then wipe off any excess with a soft cloth. The final owner then can renew the surface by just applying mineral oil.
I personally use this on any salad bowls I make, including for my own use. It wears quite well.
