Sanding
Sean Troy
>Hey all, I'm working on a maple platter and have it dry sanded to 600. What can I do from here to get the best look to pop the quilt? Thank's, Sean
Sanding
Sean Troy
Re: Sanding
theeviltwinn
>Check with a magnifying glass for scratches. Sand to a higher grit if not satisfied. Wipe on a coat of boiled linseed oil. Let dry for a week. Finish as desired.
Re: Sanding
georgetroy
>You can do a trial finish on some scrap wood. Do Deft clear wood finish and then an oil. How about Waterlox or Urethane oil first? With the trials you might fine the one you like best or close to what you are looking for. GT
Re: Sanding
Sean Troy
>That may be a good way to go but I was also wondering if sanding further with higher grits may show off the grain even better. Thanks, Sean
I agree - Boiled Linseed Oil. but..
Jim K in Trappe PA
>it will darken the wood a little. I have built a lot of furniture using tiger maple, and applying BLO has always been one of the most satisfying parts of the process. The grain really jumps out.
Re: Sanding
Keith Tompkins
>HI Sean, you can also dampen the surface, and allow to dry. This will raise any deep scratches to the surface, where they can be sanded with 600 grit or finer.
