Why Power sand?
Why Power sand?
Why Power sand?
RK in Milw
>I have always used an inertia sander (Sorby Sandmaster)for sanding bowls and vessels. What, if any are the advantages of power sanding?
RK
Re: Why Power sand?
Re: Why Power sand?
TD
>2 things:
Sanding the very bottom of a piece and sanding a natural edge piece or one that has big voids. Most other areas can best be sanded just by using the rotation of the lathe. Mind you that I wear out a close quarter drill per year so I do not necessarily practice what I preach here. I like to sand with my finishing oil whenever possible and I do not like to do this with a power sanding disc because the disc is shot after use. But sometimes on some woods there are those radial bruised lines that just won't go away (yeah, I get them too) and power sanding speeds the process up considerably. Wood that has strong contrast between sapwood and heartwood sometimes cannot be sanded with oil because of color migration from the dark wood into the light. And the "button" on the bottom of the bowl can be removed much faster by power sanding than any other way that I know of.
TD
Re: Why Power sand?
Re: Why Power sand?
RK in Milw
>Thanks for the insight. I haven't run into most of those situations yet, but anything is possible tomorrow. I sure learn a lot here.
RK
Re: Why Power sand?
Re: Inertia and power sanding tip.
Al Crandall- NE of Indy
>I attended a sanding presentation at the Ohio Valley Woodturners Guild Symposium a while back. One of the tips presented was to power sand first, and then use an inertia sander with the same grit for a few seconds before moving on to the next grit. The inertia sander will spin at a different rpm (usually slower) than the powered sander, and will leave a different swirl pattern. Supposedly makes the next grit take less time. For a cheap inertia sander, it was suggested that a pneumatic right angle die grinder from Harbor Freight be used, but without any air.
Re: Why Power sand?
Ric Taylor
Ric Taylor
>The Harbor Freight tool is exactly what I use. I bought the cheapest one on the shelf, and it works great.
Ric
Re: Why Power sand?
Re: 3 Reasons
RussFairfield
>1. Power is faster
2. Power lets you sand in the center where there isn't enough wood velocity to rotate the passive disc sander.
3. Power lets you sand with the lathe OFF.
You can spot sand where it is needed rather than the entire piece of wood, and you can sand the surfaces and edges on any surface that isn't continuous.
Re: Why Power sand?
Re: Why Power sand?
georgetroy
>In the past when I used power sanding I would get carried away sometimes and over sand. In a bowl for example you have sap wood and heartwood. I can almost guarantee that the sap wood or soft wood will sand faster and cause waves and humps. Red oak would be a good example of this. GT
Re: Why Power sand?
RK in Milw
>Thank you Al - what a great tip using a die grinder as an inertia sander! This has been bugging me. I wore a Woodcraft sander out in 3 months and wore out a Sorby sander in 6 months. I checked Harbor Freight and they have a die grinder that is on a 105 degree angle which should be perfect. It's amazing that at $49 they can make a unit with bearings that will turn at 20000 rpm while Sorby and Woodcraft use crappy bronze bearings that can't take a moderate amount of use. Thanks again!
RK
Re: Why Power sand?
Re: Inertia and power sanding tip. *LINK*
Chas
>Having had replacement parts for my Sorby (gratis) due to bearing wear etc. and failures with several other shear sanding heads I finally found the answer for me in the Grip A Disc system which has ball bearings in the head. This rotates much more readily than the Bronze bearing efforts and does not generate as much heat.
Don�t know who the stockists are in the USA but a UK source is in the link showing pictures of the device.
Grip A Disc
Re: Why Power sand?
Re: Why Power sand?
JKJ in East TN
>I do much of my sanding with the the lathe off, slowly rotating the work back and forth by hand. I get more control, can concentrate on problem areas, and can more easily see when I've sanded enough to remove scratches from the previous grit. Throws less dust around the room as well.
The other thing - it often seems better to sand the opposite direction from that the bowl rotation would drive. I think this sands faster, especially with coarser grits where you can actually feel and see the difference. I play with the disk location and the rotation direction to find the best combination for a particular shape.
Make dust, not war
