Finish On Walnut Slab
Sam Scalzo
>I am making a table top from a Walnut Slab that has been drying for about 10 years. I sanded it and put a coat of deft and it never dried.
What did I do wrong?
Sam Scalzo
Re: Finish On Walnut Slab
>Perhaps your Deft is past its prime?
Tommy
RussFairfield
>Deft is a lacquer, and as such it is a finish that dries by evaporation of the solvent. There should be nothing in Walnut that will prevent that.
Old Deft just gets a thicker consistency as the solvent evaporates, but it can still be used with the addition of more thinner. Even when it has hardened in the can, a lacquer can be melted into the solvent and used. Like other nitrocellulose lacquers, it turns a brown color after a few years.
An oil finish, or oils in the wood, can keep the lacquer from sticking to the wood, but it shouldn't prevent the solvents from evaporating and leaving the finish behind.
Have you thinned the Deft with anything other than lacquer thinner, maybe with something like Mineral Spirits or alcohol? Or a retarding thinner? Is the shop cold and humid?? Any of these could prevent the solvents from evaporating. Other than that, I have no idea what is happening.
