Bandsaw lighting solution
Dave Shombert
Dave Shombert
>I use my bandsaw a lot, mostly for precision cutting. So I gotta be able to see my layout lines clearly. I had one of those "machine accessory" lights for years, but it seemed like it was always in the way. If it was providing light where I wanted it, then it was in a place where I'd bump my head against it in the middle of the cut. Plus, it was hot. Then I found this little guy at a Lowe's, and it's perfect. One of the many Dremel accessories. CLip it on the guide post and you can shine the light right on the cut, it's out of the way, and there's no heat. Its only drawback is that I keep forgetting to turn it off when I'm done. But I'll learn that habit eventually. So useful I just had to share it.
Dave Shombert
Elkins, WV
Re: Bandsaw lighting solution
Gary in Zirconia, NC
>I also put a small light on my bandsaw. I wired it in to the switch so when I turn on the saw, the light goes on.
Dennis Daudelin
>Dave, this is really helpful!! I've got a large 2 bulb fluorescent fixutre but it's not enough. I'm now going to be on the lookout for one of these dremel lights!!
Thanks for sharing,
Dennis
>Dave I agree. I have a really crappy clamp light on my bandsaw and it gets in the way all the time and is never in the right spot. I saw those lights the other day when I was looking at getting a new dremel. I will check them out.
