A55 Smoothing Plane
Determining speed on Mark Kauder's VS Jet Mini mod
Basil Biberdorf
>I'm finally getting around to attaching the Vega variable speed motor kit to my non-VS Jet mini. I'd like to get a real determination of the motor's top speed, so I know what range I'm getting on the output side.
What's the best way to go about this? The info sheet that came with the motor suggests a tachometer, but that's more money at trouble than seems wise here. Perhaps someone can post the output speed for a given resistance on POT1 (the potentiometer at the top left of the control board)? I could then adjust mine to the same resistance and assume that gets me within 10%?
Thanks.
Re: Determining speed on Mark Kauder's VS Jet Mini mod
Brian Hahn in SW Wisconsin
>One possiblility is to use that annoying strobe effect from fluorescent lights. The light is brightest at the peak of each half of the power line cycle, or 120 time per second. This is 7200 strobes per minute. If you put a wheel on the motor with four equally spaced marks, the marks with stand still at 1800 rpm (7200/4). Six marks would be 1200 rpm, 8 marks 900 rpm, etc. You should also see double marks at half those speeds. In my experience, the cheaper tubes have a stronger strobe effect and one peak will be slightly brighter than the other (don't know why).
