Three point tool
Three point tool
Three point tool
Fred in NC
>I am planning on making a three point tool, and a jig to grind and sharpen it. If you are using one, I would appreciate if you let me know the diameter and length, NOT including the handle. (In other words, what sticks out of the handle). Thank you !!!
Re: Three point tool
Keith Tompkins
Keith Tompkins
>Fred, I just saw an article on making the tool and the jig to sharpen it...in the AAW journal, or Woodturning design magazine, I think.
Fred in NC
>Thank you, Keith. My AAW came in today, but I could not find the article. I have a hard time finding the WD magazine and I am not planning on a subscription because they seem to get lost.
>Fred I think it was in last months AAW journal. They also had a short video on how to use it on the AAW website.
Colin Spencer
>Fred, I made mine from a piece of 6 inch long 3/8" / 10mm HSS bar that I bought from Ashley Isles in the UK. About 1" is in the handle and so 5" projects. I did mine free hand on the grinder. The most important thing in my view is to then flaten each of the faces on a disk sander. I then sharpen it with a diamond file. I made this tool 18 months ago, use it regularly and it hasn't been anywhere near the grinder since I made it. Hope this helps. Colin
>Fred I made mine from Drill rod. I sharpened it by putting a hex nut over the shaft. I drilled and tapped the side of the nut to accept a set screw. Then I installed it on the shaft and just put every other flat on the grinder tool rest. I'll have to measure the angle because I don't remember what it was. I'll be in the shop tonight so I'll try to remember.
JKJ in East TN
What a great idea.
Great idea !!! Thanks ! .
Fred in NC
Thank you everyone !!!
Fred in NC
>Wish I could take responsibility for being that smart but my friend Dave in the Nashville club came up with that idea to grind a different project that had 3 sides. I just modified it for this tool.
>I agree, a great idea! I have a suggestion that might be an improvement: I make all my ferrules out of brass compression nuts, which I thread onto the handle with an open end wrench. Installation instructions are available on demand. This should kill two birds with one stone.
Here's an example. It's not a three point tool, but you should get the idea. For this purpose, you might not want to round off the corners, and if you decrease the diameter of the handle shoulder, you won't need to fiddle as much with your toolrest setting.
Instructions Reposted, for Clem
Drill a hole for the drillrod in your handle stock. install the drillrod in blank. mount your Jacob's chuck in your headstock. Slip a ferrule over the drill rod, threaded end towards the handle. Chuck the drill rod. Turn tenon, as in above photo between centers. Install nut using open end wrench. Turn and finish handle. Part off, back off tail stock, finish butt end of handle. Remove tool from chuck. Grind bevels, per John's instructions.
One of these days, I need to upload the rest of the photographs.
Thanks, William.
Clem Wixted
Greg Jensen
>Both Alan Batty and Bill Jones say a 5/16" is the best size. I made one by purchasing a 5/16" aircraft drill bit. These have a short fluted section and a long shank. I use the edge of my grinding wheel and gouged the drill shank at about the point where a normal length drill bit is. I then snapped the drill at the this piont into two pieces. I used the short drill bit section to drill a hole in the handle and then used the shank to make my three point tool. When sharpening just remember one cutting edge is alway pointing strait up at you.
