200+ woodworking book reviews
Which Drill For Power Sanding
Michael Schneider
>Hello All,
I am looking to pick up an electric drill for power sanding.
I use an air drill today, and like it. But when the big air compressor kicks in it gets a little noisy.
Which electric drill do you folks use for power sanding?
Thanks
Mike
Re: Which Drill For Power Sanding
Niedling
>Mike,
I use a Milwaukee 3/8" close quarters drill, 0-1300 rpm. Souix makes one that is identical. It is much easier to handle and control than a regular designed drill. These drills are usually sold for around $130, but if you shop around and check EBAY, sometimes you can find a deal.
Earl Eyre
>I use one of the knock off close quarter drills that are sold on e-bay. If you watch the auctions you can get one quite cheap. I've used it for a couple years now and it's still going strong--for $25-$30 bucks I certainly can't complain.
Earl
Russell L. Babbitt Jr.
>I was told Souix is the manufacturer for the Milwaukee.
Juergen
>Have you ever tried using the air drill without the air? It freewheels and sands better than some of the home made passive sanding disks. Usually when my sander, a random orbital unit, drains the air tank I just continue sanding using it like a passive sander till the compresssor catches up.
Terry Quiram, Roanoke Illinois
>I bought the cheapest B&D 1/4 VS reversable I could find at Sears. It had a 1 year warranty and I bought the additional years warranty. I plan to wear it out before the warranty is up and then let Sears replace it.
Terry
JKJ in East TN
>Make sure the drill is reversable and variable speed.
I agree about the Milwaulkie close quarters drill - I've used one for years now. Unlike a standard drill, you can hold this securely with one hand. Unlike a standard drill, it is designed to be gripped very near the chuck which gives you far more control in addition to being well balanced. I often sand trouble spots with the lathe off, turning the work with my left hand - difficult with a standard drill.
Even if you have others, the close quarter drill is handy for other jobs such as installing cabinets since it will reach into tight spots.
Bill Neddow
>I love the shape of the Milwaukee (Sioux) drill for sanding. But it was not made for that and the Milwaukee five-year warranty is void if they find sanding dust in the motor. The tool has a major flaw -- the rear bearing. It simply will not last with the added stress of a sanding disk (versus a drill bit) and the sawdust. You can extend the life by regularly blowing the dust out, but the rear bearing will go. When new, the rear bearing will last me about 10 months. After that, with replacement bearings, it last about three months. I expect more from a drill when I am paying over $300 Cdn, including tax. The rebuld (from various shops) cost $80 Cdn. I have tried various shops because I have tried to get a shelded bearing installed. The Millwaukee repair shop categorically refuses to do this -- they will only use Milwaukee parts. Others say they have done it, but so far none of them have. Some weeks ago, my last Milwaukee died (for the fourth time) and I took it apart myself. ( This is a kiss of death for the drill as I have never found a way of getting all the linkages back in place for the paddle on/off switch.) Ball bearings all over the inside of the casing and no shield (again). I threw it in the garbage and ordered a knock-off, which arrived in a couple of days. Cost me $39.99 Canadian. I have been using it for over a month now, and like it. It seems well built and has lots of power. If it lasts another two weeks, I will be saving money. And I think it will -- it does not make the funny washing machine noises the Milwaukees do before they die. This is not to knock the Milwaukee line of tools. I have other drillls made by them and they are fine. But on this one, which they buy for other sources, there has been this flaw for years and it has been discussed numerous times on various web sites over the years. You think they would address the problem.
Devon
>I've got one of those same knock off goose neck drills from Shopsbs.com It looks EXACTLY like the milwaukee - have had it over a year and its still going strong (I keep expecting it to die any day tho becuase of all the noise the bearings are making). Even as a throw away, $25/year is pretty good in my book. - Devo
Ric Taylor
Electric Drills are Noisy Too
Ric Taylor
I have the solution
TD
>Bill, I use the Milwaukee close quarter drills and you are correct, they were not designed for sanding but for drilling, thus the same air flow that cools the tool is also sucking dust into the motor chamber. Blowing this out frequently will help but you should also change out the rear bearing to a sealed bearing instead of the shielded bearing that it came with. If you have trouble finding this bearing I can ship you one. My servicing dealer will install a sealed bearing but not under warranty. It isn't much trouble replacing the bearing but you really have to watch the position of that trigger rod when going back together with it. Taking a photo as soon as you remove the side cover will help.
TD
I also have a suggestion
Darryl Hansen
>The shielded rear bearing can be found at Boca Bearings in Florida. Less than $10 as I remember. I have the parts diagram blow up if you are interested. As I remember I got it form the Milwaukee web site. there are two modles one has the switch at the back (old version) the other on top. The wiring placement is critical but manageable. The trigger mechanism is tricky but again once done does make sense.
Peter Charles Fagg (UK)
>Michael, I buy the cheapest electric drill possible because the usage and demands I make on them means that the rear bearings die after about 8 months. I always try to buy those that have a fixed speed, none in particular, and no hammer selection, just makes them cheaper.
"Ferm" that are made in Holland are reasonably priced and are not too noisy.
Regards Peter.
The Wood Spinner / Bill Hale
>Check ot Ridgid tools at Home Depot. Life time gurantee.
If you buy there 18 volt stuff they will even replace batteries-- FREE.
Bill in Casa Grande, AZ.
Re: I also have a suggestion
Bill Neddow
>Thanks Terry and Darryl. Terry, I remember you making the same offer when my first Milwaukee died. The problem is, by the time you pay shipping, Canadian taxes, and the brokerage fee (so much for free trade!) the cost of the bearing excalates wildly. It is also too late, as I threw the Milwaukee drill out in the garbage, minus its cord and chuck. Looks like I will be sticking with the Chinese knock-off for now.
Rob Wallace
Rob Wallace
>Darryl: Do you have a stock number for this sealed bearing that you could provide for Boca Bearings and any other ordering information? It sounds like I should have one of these on hand for when my Milwaukee's bearing gives out. I'm sure others may also work under SPI (spare parts inventory) guidelines. Thanks, Rob
Boca part number
Darryl Hansen
>Sealed bearing EE1 1/2 2RSM3GSR They are real good an helping identify your bearings and needs...1-800-332-3256 e-mail if still good bearing@gate.net The bearing cost about $9.00 and they send it through US mail so there is no shipping....Darryl
