Re: McNaughton System question *LINK*
Bill Grumbine (Kutztown PA)
>Hi Ron
I've been using the KM tool for years, and have taught a whole bunch of people to do the same in my shop and in others. I am not sure what exactly you mean by the top bowl, but if you mean the largest bowl of the blank, the one we call the "money bowl" around here, then there are a couple of things I can suggest right away.
The cores you take from any blank need to follow the outside shape of that blank fairly closely if you want the maximum sized core. However, it is better to err on the side of shallow than go too deep. It is not very satisfying to have a perfect core if the main bowl is now a funnel. When I turn a bowl that is going to be cored, I will turn it to the shape that I want to turn, not necessarily one that will core out with a particular knife. Once I have it the way I want it, I will get out the knives I have and look them over to decide which one is going to do the best job for this particular application. As has already been mentioned, I will lay that knife on the wood looking down from the top and visualize the way it is going to penetrate the blank and where it will end up. This is an estimate, but as you practice the technique, you will gain in accuracy.
It has been my experience that the steeper the sides of the bowl, the smaller the core is going to be relative to the next largest bowl. If the bowl is very shallow, you can get more cores that are closer in size. Again, if you take a core that is different in shape than the main bowl, it is going to be significanly smaller as well. Once I have selected the knife and estimated the angle, I proceed to core the blank. If I want more cores, I repeat the process. I will humbly suggest an article I wrote a while ago on coring bowls which is on my website. The link is below. Good luck with it, and if you have more questions, I will be glad to try and answer them.
Bill
Coring Bowls
