Lemon bottle stoppers. PICs
Dave Smith, Longview, WA
>A customer asked for bottle stoppers to use with bottles of lemon liquor he makes and gives to friends. I suggested lemon shaped stoppers dyed yellow. This is what I came up with. About 1 3/4" tall and 1 1/4" wide. The picture doesn�t show the little dimple in the top to simulate the stem scar. Turned from pear and dyed with Homestead lemon yellow(of all things) alcohol dye. Finished with several light coats of Deft gloss lacquer.
The stoppers are brighter and more yellow that the picturs show.
Comments welcome.
Dave Smith
Turning vegetarian in Longview, WA.
Re: Lemon bottle stoppers. PICs
Very nice ...
Fred in NC
>Now, if we could only produce a "lemon peel" finish ON PURPOSE !!!
?? concerning rubber stopper
Gary Ratajczak
>Hello:
Nice job on the stoppers. I see that you used some of the rubber stoppers. Do these require a special dowel to hold them, or do you just use a standard one. I bought a package to try. I have seen some references to a stepped dowel. Was not sure if I needed to cut a step in teh final stopper myself.
Thanks
Jim Shaver - Oakville, Ontario
>Nice Ones Dave,
I see lemons, I see Christmas Tree Lights too...but I see you have been busy making good things, way to go!
take care,
Jim
I turn my stoppers a little different.
>Hi Gary,
I turn my own dowels mostly out of big leaf maple because I have a lot of scraps from lumber. I am trying to get an article written about the process along with pictures. Basically I put a piece of 2" square, more or less, stock in my strong hold chuck. I usually start with about a 5" long piece. Taper the end down to a 1/2" tenon that is a little bit bigger than the 1/2" hole you will drill in the blank. Seat the blank on the tenon. If it is loose you can wet the hole with water to get a friction fit. Bring the tail stock up to hold the blank secure while you turn the shape and sand it. Part off the waste on the tail stock end and sand it smooth.
Since you are using a wood dowel to hold the stopper you can use a skew or spindle gouge to true up the end of the piece with out worrying about hitting any metal. When the tenon is too damaged to hold an other stopper turn a new tenon on the end and away you go. Also, mark #1 jaw on the turning square so you can remount it and not have to turn a new tenon. Fine grain, dense wood work best for the tenons. Pine, alder, red oak and walnut don't work very well. DAMHIKT
No special jigs or parts for you to buy.
Dave Smith
There are reasons why I don't make any money in Longview, WA.
Keith Tompkins
Re: I turn my stoppers a little different.
Keith Tompkins
>Dave, I think these are great...if I received a gift of a bottle of wine with one of these stoppers, I would be truly impressed. Neat!
Very cool!
Ed Kelle
Jennifer@Indy.USA
>These are great Dave! I think a bit of "lemon peel" affect with some texturing might be kind of neat as someone else sugested. What a great idea for bottles of lemon liquor. Sounds like something good to put into a 7-Up! Slurp! Ooops...sorry...is that something you drink after dinner in a tiny glass with a pinky pointing?
By the way....I just did a run of a bunch of bottle stoppers and to this day...I can't thank you enough for showing me how to make that dowel jig for these. So easy....so simple....but I bet I never would have thought of it.
Jen :)
Scott Greaves, Blackfoot Idaho
>Hey Dave!
These are so very cool! I like them!
Scott.
Don Henthorn
>Just discovered something. I was getting broken links instead of pictures and wondered why others were seeing pics. Finally turned my Zone Alarm firewall off and the pictures came right up. Hope I can remember that.
OT Firewall
Bruce Wiseman
>That's kind of strage. I run Zone Alert Fire wall and I get the pics. Which browser are you using?
Molly Winton
