GRizzly vicmarc copy
>OK I've now used the Grizzly copy of the vicmarch 100 chuck, a bunch. I'm guessing, but I've turned around 20 or so bowls, 30 or so ornaments and a lot of other small stuff. It's pretty darned good but simply isn't as accurate as the Vicmarc. For bowls and bigger things it seems to work fine. I didn't start to notice inaccuracies until I was trying to turn really intricate stuff that required precise alignment. The grizzly would be off just a hair. it is a decent chuck for most things but when you start looking at a few thousandths of an inch accuracy it just isn't there. It's definitely worth $100 and would serve most people quite well. Apparently there have been a few quality problems so I would check on the Grizzly return policy before buying. As near as I can tell from reading the different news groups the happy buyers outnumber the unhappy ones by a fair margin but then this is a very very unscientific study.
Re: GRizzly vicmarc copy
Jennifer@Indy.USA
>Thanks for the feedback John. Much appreciated. I'm still in debate mode over this one. I'd really like to have a smaller secondary chuck.
Jen
Vicmarc.fan
>I had the same problems with the chuck on small stuff. Didn't try a larger piece like a bowl though. Sent mine back and took the 10% hit plus postage.
Ron
Ken Grunke from SW WI
>John,
I wonder if it would be worthwhile to take the whole chuck to a machinist and have them true up the jaws just a bit. Grip something like a bronze bearing bushing in the inner jaws to lock them down, and just take a light cut on the outer jaws, inside and out with a boring tool.
That's what I might do if I had that chuck, but I'm lucky enough to have a metal lathe, too.
>Ken it's not the jaws, those are Vicmarc jaws that I have on it now. It's the slop between the helical and the inner jaws. I don't believe the problem is bad enough for that. It only shows it'self when doing extremely accurate stuff. Not even your average serious turning would show this error.
>Jennifer. Ideally I would save up and buy the real vicmarc or if you can't swap jaws from whatever you have now a Oneway Talon is a good choice. I've thought about buying the smallest vicmarc which is a Tommy bar chuck. I would use this one solely on my mini lathe.
