A55 Smoothing Plane
Worm screw pre drill size
DougJ in Crawfordsville, IN
>I have been using a small 3" face plate for my initial blank roughing. I now would like to venture into using the worm screw that came with my Talon chuck. What is the size of drill bit used to pre drill the blank for the worm screw to fit but not be to sloppy as to let the blank wollar about?
Thanks for any help.
Re: Worm screw pre drill size
Sean Troy
>5/16th
>I usually use 3/8" myself.
Curt Fuller
>I also use 3/8". But in softer or very spalted wood 5/16" would probably be better.
Kevin Gerstenecker
>Doug, I use a 3/8" in harder woods, such as very dry blanks and Exotics. For softer or green wood, I use a 5/16". Works pretty well that way for me, and I use my woodworm screw almost exclusively.
Terry Quiram, Roanoke Illinois
>I use 3/8, and I always use the tail stock. For dense, hard wood I put a little wax on the threads. It makes removing the bowl from the screw a lot easier.
Terry
Carole in VA
>Doug, I also just started using my woodworm in the past month or so. I have only used it in maple (soft) and cherry so far, but am amazed at how solidly it holds. I use a 5/16 hole.
Juergen
>The rule of thumb I learneed a long time ago when prdrilling the hole for a screw is to drill it the diameter of the screw shank. If the wood is soft drill it 1/32" smaller.
Re: Worm screw pre drill size *LINK*
Dave Peebles Lyons, Ohio!
>Hi Doug,
Oneway says 9mm or 11/32 hole. I bought the right size drill bit for mine. It was pretty cheap money for the bit.
Here is a link to the pdf on the proper size to use.
Dave
http://www.oneway.on.ca/pdf/ow-talon.pdf
JimQ
>While we are on the subject, how about the size for the worm screw for the Super Nova?
That's what mine is
Carole in VA
>They say 5/16.
>Doug,
I have not read the other responses, what I do is measure with the calipers the shank between the threads, and that is the size of the drill bit needed to make the hole.
mis dos centavos
Jorge
