Buffing
Buffing
Buffing
Sean Troy
>Hey all, how long do you wait to buff a piece after using an oil based poly finish? Thanks, Sean
Re: Buffing
Re: Buffing
georgetroy
>I know one woodturner who waits 30 days. He is using Urethane Oil from Craft Suppllies. I can and do buff immediately when I used MinWax Tung Oil and Antique MinWax Oil. With these two finishes you buff with out any rouge. For the Poly you may won't to wait a couple of Weeks after final application. GT
Re: Buffing
Dick Hines
Re: Buffing
Dick Hines
>I useily wait 2 weeks when using Watco
Re: Buffing
Re: Buffing
Ron McKinley
>I only turn small boxes, bowls, cups, etc. out of dry wood and use either Watco or Minwax Rubbing Poly and after two coats I rub it out well while spinning on the lathe. When I don't get any residue on the paper I know it's dry. Then at the end of the day I buff and wax all my projects. I also live in the Mojave Desert where humidity is not a problem.....Ron
Re: Buffing
Re: Buffing
Mike Schwing from Md.
>Sean, I wait 2 weeks after the last coat of Watco, at a minimum. If using another type of drying oil, I wait till the oil feels dry to the touch (not tacky) and then wait at least 2 weeks. I know from my experience that the Watco bowls will be dry enough 2 weeks after the last coat. Others I'm not so sure of get more scrutiny.
You'll know if it wasn't ready as the heat of buffing will bring up to the surface any oil still in the liquid state, creating a bit of a mess.
Re: Buffing
Re: Buffing
George Van in WI
>With 100% tung oil/Waterlox I have been waiting a month Sean. It may not be necessary for me to wait that long but better safe at this time. I should make a test panel and see if I can shorten the resting time.
Re: Buffing
Re: Buffing
Sean Troy
>Thanks all for the response. I think I'll play it safe and wait a little longer than I was going to. Sean
Re: Buffing
Re: Buffing
Tony - Memphis
>I do the same thing for small stuff pretty much. I've gotten in the habbit of using wipe on poly or gel poly for small stuff for durability. I usually let it sit overnight, then polish it and wax it. I use the Micro mesh stuff for polishing.
Tony
