Small rhododendron NE hollow form. PICs
Dave Smith, Longview, WA
>Rhododendron burl from wood I was given in August. The tree had been down and cut into firewood lengths for about a week before it was given to me. The waxed blank sat outside my shop until early November when I roughed it out. I wrote the date on the bottom with a new gel pen and it disappeared while soaking in alcohol. Not all gel pens are created equal. The roughed out hollow form soaked about a week before I had a chance to take it out. It was roughed out to about 1/4". Top through the neck is 1/16" thick. Thickness increases midway through the body to 1/8" at the base.
Nice eyes on the low side. Base 1 1/4". Body 2 1/4 maximum and neck 1 3/4".
Some flame figure on the high side. Height is 3 7/8".
The data card for the hollow form. I took the piece out of the alcohol on the 12th and wrapped it but didn�t take the first weight until 24 hours later. All weights are in grams. The piece was effectively dry on the 17th when I took a long weekend. It only lost 3 grams over the next week before finial turning it on the 24th. Finished piece weighs 33 grams.
The number (224) is the sample weight of the soaking solution when I took the piece out and corresponds to 92% alcohol.
Sanded to 600 initially and between coats. Finished with 2 coats of Rockler�s Gel Polyurethane. No buffing.
I asked about turning rhododendron a couple months ago and the advise was it will crack and split no matter what I do. I beg to differ with the advise. I also have two crotch bowls that also dried without cracking or excessive warping.
Comments welcome.
Dave Smith
I can turn most anything no matter how long it takes in Longview, WA.
