We value your privacy.
>This piece is headed for a gallery tomorrow along with several other pieces. It will be a part of an exhibit of well-respected studio furniture makers. I am the only turner invited to participate in the show.
6" Cherry burl form with an ebony collar and finial with a cherry burl tip. the finish is Bush oil. While I don't consider this a "signature" piece, forms like this help pay the bills. Any comments are welcome.
I love the balance you have created with the burl tip - it nicely ties the piece together and certainly avoids the "add-on" look of some contrasting finials. It also suggests an oil lamp with flame, adding to the dynamics of the piece. Very nice.
Since you said it is not a signature piece, perhaps I won't feel so guilty if some day I suddenly realize this influenced one of my turnings!
I'm curious... you said this is a "cherry form". Since I can't pick it up and see for myself, does that mean it's solid burl, hollowed from top then the collar and finial glued on, hollowed with something removable on the top (like a box), or what?
>Hi John, thank you! This is a regular old hollow form, with an ebony collar glued on. I always make a small tenon where the collar fits over the hole for added glue surface. The hole through the collar is tapered, as is the finial. Similar to a morse taper...or a decanter stopper. The finial is removable, the taper fit compensates for seasonal changes.
>Hi Barry, thanks for the comments....the wall thickness is about an eighth, but I usually leave a bit extra material near the foot for added stability. the foot is 1/4" thick.
>Thanks for the kind comments everyone! Early in my woodworking career, I learned to turn Windsor chair components. Many pieces were turned for reproduction museum pieces, restorations, and (gasp) other chair makers. My finials are loosely based on those same forms; in fact, this finial is half of a fancy center stretcher for a chair....with a cherry tip.
I enjoy pushing the envelope on some of my work, but traditional spindle turning is just as much fun.
>Congratulations on your exhibit invitation Keith. Your imagination and experience always show in your turnings. I never would have thought of the cherry topping.
>Very delicious piece Keith :)...you know I get so envious when I see finials of this caliber. I really need to discipline myself and learn to do this....or at least attempt to make them. The form of the vessel is wonderful and I love the fantastic surprise at the top of the finial! Yum!
I like the whole works - v.v. nice. I'm curious as to the attachment between the two finial pieces... I did something sorta similar (but not as pretty!) once in Ebony, and turned a little tenon on the tip, which mated with a drilled hole in the finial base. Do you have a better way ?
I've never used a tapered fit between the hollow form and the finial -- great idea.
>Wow!Thanks again everyone. It seems lots of turners have trouble with finials...there is a lot to consider to make a good one. If it helps, here is my thought process. On this piece the collar is undercut, which I think gives a nice, even oriental effect. To keep the same theme throughout the finial, all the filets are undercut also. The filets are an important part of spindle turning, they add the finishing touch, creating shadows and separating the elements. The foot also has the same effect, in an attempt to tie the theme together. The bead on the finial is asymetrical; a round bead does not have the balance I'm looking for.
The cherry finial tip fits the "golden rectangle" very well. Using that as a proportion tool is almost like "cheating", as it is difficult to produce a bad form. I like lots of definition in finials, from large diameter to small...it adds a dramatic effect. Yes, the small diameter is fairly weak, as Russ points out, but selecting straight grain wood helps a great deal.(just like chair parts). Finials without this definition just don't have the same appeal to me. Drawing finials in a scrap book is the best way to visualize these forms, and practice is invaluable. I turn a goblet or finial every time I turn to stay sharp...
>I forgot....I start a finial between centers, then mount one end in a chuck or jam chuck. This frees up one end, which I drill for the finial tip, then turn to shape. The tip is turned between centers, leaving a tenon on one end. Remount the chuck, glue in the tip, and finish turn the point and sand.
I then make a jam chuck for the point, and bring up my tailstock to hold the base of the finial.Since I started between centers, there is a divot from the drive center to accurately center the piece. I now can fine tune the taper to fit the collar, and turn a small detail on the end of the taper.(The finial point is driving the turning)
