Another Natural Edge Bowl Question
Doug Reynolds in Seattle
>Following up on my earlier post, if I make the cherry bowl from wet wood it is going to change shape as it dries. I assume I can sand to some point while the wood is still wet. I would think though, it will still have raised grain once it dries. To what grit should I sand now and, at what point can I apply the finish?
Re: Another Natural Edge Bowl Question
Kevin Gerstenecker
>Doug, Cherry will move quite a bit if turned green. Of course, that depends on how much moisture it still in the wood. I have turned many Natural Edge Bowls from very green wood. I follow the same procedure with Nat. Edge work as I do with conventional bowls turned green. Soak in Alcohol, wrap, and dry. After about 2 to 3 weeks, they are dry and can be finished. Sanding green wood tends to clog up sandpaper, and it can be more trouble than it's worth. Cherry likes to check as it dries, but using Dave Smith's Alcohol method has garnered a 100% success rate for me with most wood, and especially Cherry.
Brian Hahn in SW Wisconsin
>I hand-sand mine all the way to 400 while it is still on the lathe. Use wet/dry sandpaper and water to lubricate. Do this with the lathe off, otherwise it can get real messy. Place a large shallow baking pan or dish pan on the lathe under the piece to keep the water off of the bed. I normally let it dry completely, then do a final hand sanding and apply the finish. On the other hand, some people apply an oil finish while the bowl is still wet and continue apppling finish as the bowl dries. Both ways work.
Brad Vietje
Brad Vietje
>I am still playing with the alcohol soaking method, but I usually do a lot of wet sanding on the lathe -- with the lathe running. Yes, the bowl will warp, and yes, the grain will be raised in the drying process, but that's no big deal at all.
By wet sanding, I don't mean dry paper on wet wood -- I mean a bowl of warm water into which I dunk the paper repeatedly. Yes, it makes a little mess, but these's no dust, and I'll disagree with the previous post about the sandpaper clogging. With wet sanding you create a slurry of dust and water, which you rinse off by dunking in the bowl of water (or oil, if you're lubricating the sanding action with oil). In cold weather, the warm water feels pretty good, too. BTW: when I wet sand with oil, I use a squeeze bottle, not a bowl.
I usually sand up to about 320 with wet/dry paper or cloth-backed Klingspore abrasives, then dry via your favorite method, (alcohol would be a good choice, I think), then hand sand the dried bowl with a little more 320 followed by 400. For bowls, I don't usually sand any finer than that, since I don't favor a very glossy finish (as opposed to artsy objects like ring boxes and sculptural pieces, which I sand to finer grits).
A sheet of plastic, or a chunk of an old shower curtain will keep most of the mess contained, but wear something you won't mind getting dirty -- I usually end up with a stripe of slurry up and over my left shoulder.
Your biggest challange when sanding natural edges on the lathe will be keeping the bark (and your fingers!) attached (Cherry bark is pretty prone to catching on sandpaper, fingers, sleves, etc...), and in keeping the bark edge as crisp as possible. Its very common to see natural edged bowls that look great except for the rounded leading edge. With practice, you can get nice crisp edges without roundover.
Safe Spinning,
Brad Vietje
Thetford, VT
