Sharpening & using a potato peeler
Charles Bjorgen
>When on Thanksgiving morning my wife enlisted me to peel the potatos that would become the mashed accompanyment to our turkey and dressing holiday meal, I was immediately reminded of my frustration the last time I accepted this task. The potato peeler simply would not hold an edge.
We have four of the most basic peelers made, the kind you buy for a buck or two at your supermarket. I had previously looked at several methods for restoring the edge of the peeler, even looking longingly at my Wolverine jigging system as well as some honing guides I use for chisels and plane irons. I had previously tried sharpening stones but finally settled on a diamond paddle hone, blue plastic, probably fine grit, the kind we use for touching up edges of our skews and gouges.
I discovered quickly that it only took a few strokes crossways on the peelers� edges to remove any rust and to yield a clean, sharp edge. Yet, after peeling my first potato, it stopped cutting. I then picked up the second of the four peelers, went to work with that one only to experience the same kind of loss of edge as the first one. This one by then had accumulated a jamming of peelings in its throat (like shavings stuck in a bench plane?) so I cleaned out the jam with a paper towel, wiped the cutting edge and tried it again. Voila!! It worked as it should.
It didn�t take long to draw the conclusion that my problem was a build up of the natural starches that caused the peeler to slide along the skin of the spud without cutting it. It�s also possible that my preference for peeling potatos dry before washing may have caused the buildup of the troublesome starches. Nevertheless, the job went smoothly with my newfound technique of cleaning the peeler after each potato was done.
As I pondered my discovery, I decided to Google the term �potato peeler� to see what new technical wonders might be out in the commercial world to make this job easier and more efficient. I saw none exactly like the ones I use but there were several streamlined versions available, many with the cutting edges set crossway to the handles that would encourage more of a �pull� cut. Several varieties were shaped like apple corer/peeler combinations and, in fact, said they could process both apples and potatos. These were in the $25 to $35 range.
Of special interest to me was one model of automatic peeler that is an insert for a commercial food processor. Its interior is a rough, abrasive structure that literally scrapes the peels from potatos as they are tumbled and washed inside the container. This reminded me of a large, self-contained tumbler machine I first experienced when I was on KP duty in Army boot camp at Fort Leonardwood, Missouri, in 1954. While it saved me from the job of hand peeling, my reaction was that it sure wasted a lot of potato.
The Starfrit Rotato Potato Peeler Express at $29.99 works almost like a vertical lathe. The spud is centered on bottom spokes (drive spur) and an upper section (tailstock) is lowered to hold the target. Press a button and the potato revolves as a cutter does the peeling. The picture shows a potato whose natural shape is followed by the cutter.
But back to my basic peeling tools. When peeling you�ll want to ride the bevel. Failing to do so may not result in a catch but you�ll probably take off more meat than you wish. My peelers allow for both a pull cut and a push cut. If you prefer one stroke over the other, a right-hander may need to learn to peel with his left to utilize both cutting edges. Lefties can adjust to the other side. Sounds to me like Alan Lacer.
I regret the lack of empirical data in this report. I did not use control groups to isolate differences in russets from reds, wet peeling from dry, or from the wide varieties of peelers available. I have a fair knowledge of what the scientific method is but will ask that you accept my humble anecdotal findings on this matter.
Re: Sharpening & using a potato peeler
Curt Fuller
>You know, I think that's the longest, most indepth, and informative discourse I've ever read on the subject of a potato peeler.
Charles, that was magnificant!
Clem Wixted
>Was a great discourse.
If I were to come to an anecdotal conclusion I would say that your experiment indicates that the potato peeler doesn't have to be sharp, just starchless.
Clem
P.S. My hands a still a little stiff from peeling about 10 pounds of the ground grape.
Brad Vietje
Just Turn 'Em Between Centers -- It's a Snap !
Brad Vietje
>... next Thanksgiving, or who knows, maybe even for Christmas dinner, if you celebrate that one, try peeling those spuds on the lathe ! I think the edge-holding capabilities of those inferior peelers needs further investigation ... How, for example, do M-2, M-4, 2030, 2060, V-15, and other alloys stand up to washed and/or unwashed spuds ? Russetts vs. Yukon Gold ? Starch problems with powder metals ? WHO CAN SAY FOR SURE ???
And as an aside, how do potato peelers work for turning spindles ? The push-pull variety could be very useful with reversible lathes, no ?
... there are a lot of un-answered questions here, and I think the vast right-wing conspiracy must be behind it !
Eating leftovers for lunch,
Jethro Bodine, a.k.a.
Brad Vietje
Thetford, VT
Do you want fries with that?
JKJ in East TN
Charles,
Hey, I used to run one of those about 40 years ago, at McDonald's #10 in Pittsburgh PA. Instead of the frozen, pre-blanched "instant" fries they use today, at that time they kept a basement full of 100# sacks of potatos. We carried them up the stairs, "peeled" them in the 30-grit washing machine, cut into fry size by hand, then blanched before frying. This took up a lot of space, took a lot of time, and was a LOT more work than the convenient frozen fries. But man, what a difference in taste - people today have no idea what they missed.
(BTW, this also was before the Big Mac was introduced, when the sign said something like "1 million sold", to work the register you had to add up the orders and tax in you head, and the policy was to hire only young white males, period - times sure have changed!)
Brilliant! Conclusion? The best tool for peeling
Garrett in Victoria
>potatoes is someone else.
Cheers, Garrett
I had one of those verti-lathe peelers... *LINK*
Peter Teubel
>I was called the Dazey Stripper. The blade was almost identical in shape to a ProForm cutter, but VERY thin (and fragile). The device really worked great, though. I see them on eBay alot and there's even a regular trade in spare blades there too. I just might entertain the idea of getting another one.
Dazey Stripper on eBay
ThomD
>Being a thoughtful guy, I bought my wife the first Chinese peeler I saw. These are an old tool, come in a variety of sizes, some huge. They have only one blade with the other side a swing open thing that lets you sharpen them or adjut the cut. My wife is still my wife.
Anyway I somehow seem to do a lot of peeling these days, and when I finaly tried this "gift" out, it really worked, what a tool! Certainly if you don't have the bucks for an electric one.
Re: Charles, that was magnificant!
Ed Karch in No.VA
>But we still don't know if one can peel potatoes with a potatoe peeler until it has been scientifically proven. All we have is imperical data, just rumors and hearsay until proven.
And You Call Yourself A Woodturner ! ! !
Barry Turner
>Didn't you at least give a moment's thought to sovling that potato peeling problem with a "turning" solution? How about spiking those potatoes onto a screw chuck and peeling them with a nice sharp skew chisel? :-)
Re: I don't need a potato peeler! ! !
RussFairfield
>When I want a whole potato, I bake it in the oven as a whole potato. When I want them mashed, I open a box. When I want hashbrowns, I open a bag. When I want French Fries, I go to McDonald's.
