Re: Oil over lacquer
RussFairfield
>Oil over lacquer does sound to be going in the opposite direction but there are several benefits.
The lacquer is used as a sealer, and than means IN the wood, with no film on the surface. The advantage of the lacquer sealer is that there is no blotching in the end-grain areas, and the oil builds faster because there is no wait for the penetrated oil to cure. You still get all of the advantages of an oil finish, but none of the disadvantages of a lacquer. There is less color change over time because there is no oil IN the wood, and the oil keeps the lacquer from turning orange with age.
As for popping the grain picture, lacquer on wood that is sanded to 1200-grit or higher will do as good or better a job of accenting the grain as any oil finish. There may be a better explanation, but I see it as that lacquer accents the wood grain by changes in reflectivity, while oil does it by changes in color. For that reason, oil can accent the grain on a much rougher wood surface. Reflectivity wins that race every time.
I used this same finish on tall clocks for many years. I was always amused by how many folks, some who were famous for their furniture, would admire the brightness and grain under my finishes, ask me how I did it, and then tell me that I couldn't do that.
