Natural Edge Bowl Bark
Doug Reynolds in Seattle
>Turned my first ever natural-edge bowl from freshly-felled cherry. How much of the bark should I leave on? Moss and all?
Re: Natural Edge Bowl Bark
joaz
>If thats what you want, you can leave it all on. Douse it with lots of CA before sanding. Try not to get it all over you, or the rest of the piece. If it drips where you don't want it, wipe if off quick.
>Doug Apply some finish on the bowl before you put CA on the bark and Cambium layer. If the CA runs down the wood it will leave a streak that shows up when you finish the wood. If you put a layer of finish on first you can easily sand off any overruns.
Jennifer@Indy.USA
>Hi Doug,
Sometimes it's fun to leave all of everything on... the bark...moss and all. I think it really adds to the bowl when it's finished. Non-turners are often confused as to how a natural edge bowl was made and it really begs for questions when they can actually see the outside of the tree left on. Then again sometimes I like to see a natural edge bowl with a smooth edge, with the bark completely removed and just the smooth undulating edge of the bowl left there to see and feel. Both different affects, but both really beautiful. Sometimes the second one I mentioned is attained by default....when the first idea goes out the window when the bark just starts coming off when not intended :(
Good advice from John with the CA glue. It definitely helps to keep the bark intact. Some barks hang on much better than others. I've had pretty good luck with cherry.
Have fun!
Jennifer
Ron Parsons SE NM
>Just a comment. I heard a comment on DIY Woodturning Tech. If wood is cut during the dorment period the bark will be tighter. I used to work on a ranch and the owner striped vigas for winter work. We would cut the trees in the late spring (10,000 feet alt) so the bark would come off easy.
Ed Karch in No.VA
>Yep dormancy is when the fluids are at a low level in the cambium. I had to cut a walnut in July to get ahead of the developers.When a section of log was stood on edge fluids ran out and formed puddles in my truck bed. I sliced a slab for the land ownerand soaked in alcohol to see if it would prevent cracks. There were two small checks where it would normally would have self destructed. The kicker is the bark was tight. This might work for summer cut natural edged objects.
